camaro died WTF!!!!
Old Aug 1, 2002 | 04:07 AM
microtek_10's Avatar
Car: 92 Z28
Engine: 355 tpi
camaro died WTF!!!!
I was drivin some back road, car was runnin pretty hot like usual, and i wasn't gettin any response from the throttle at all. So i shut the car off only to not have it start up again. This was at about 11 tonight. We let the car sit untill almost 4 this morning and went back and it still won't start. The fuel pump was just replaced but could that possibly be the problem??? Pretty torked off right now. Any help would be great.
Old Aug 1, 2002 | 07:26 AM
ede's Avatar
ede
have you tried trouble shooting it? that might be a good place to start.
Old Aug 1, 2002 | 11:20 AM
Car: 92 Z28
Engine: 355 tpi
trouble shooting??? hate to say but i'm unaware of what that is.
Old Aug 1, 2002 | 11:28 AM
MX265
Guest
Posts: n/a
Troubleshooting...
Troubleshooting...
The process of narrowing down the problem through a step by step systematic process.
If you provide some symptoms, the folks at this board can assist you in troubleshooting the problem.
1) Does the engine turn over when the key is turned?
2) Do your dashboard lights and or headlights work?
3) Can you hear a buzzing sound near the back of the car when the key is turned partway that would indicate your fuel pump is working?
These are just a few of the questions we have to look for in the troubleshooting process. I am sure there will be many more that will be asked. If you can provide this kind of info, I am sure these folks at thirdgen can assist in solving your car's problem.
Old Aug 1, 2002 | 12:00 PM
Car: 92 Z28
Engine: 355 tpi
The car will still turn over, all the lights and guages and what not move. There isn't a noise comin from that back at all which is why i was thinkin it might be the pump...but it was just replaced about a month ago. Why would it be doin this??
Old Aug 1, 2002 | 12:29 PM
Car: 92 Z28
Engine: 355 tpi
How do you check the codes to find problems???
Old Aug 1, 2002 | 12:47 PM
flyway190's Avatar
What are the specs on your car? (Engine type, year, induction)
Old Aug 1, 2002 | 01:10 PM
Car: 92 Z28
Engine: 355 tpi
1992 z28 25th ann. 350 L98 with wolverine camshaft, timing chain and gears, block has been decked, bored 30 over, crank is ground 10 under, 24 lb injectors, The fuel pump I just put in pumps 277lph , the 305 chip was uped to the 350 chip. With 2.73 rearend. Ive done a few free modds too.
Old Aug 1, 2002 | 01:50 PM
ede's Avatar
ede
if the pump isn't running check the fuse, the relay, and the sender above the oil filter
Old Aug 1, 2002 | 07:00 PM
Car: 92 Z28
Engine: 355 tpi
Well i went to check out the car today and it started right up without a problem......When it died it was runnin at about 230 degrees. I filled up the coolant yesterday and it'd low again but i'm not drippin ANY AT ALL. Any idea's
jklein337
Sep 19, 2018 06:23 PM
pimp2303
Jul 27, 2017 02:03 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
legendaryhero7
Aug 12, 2015 06:19 PM
