Timing, Is this Right?
Old Aug 2, 2002 | 09:23 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I was plugging some #s into DD2000 with my current setup after the cam swap.
I was adjusting the timing section and -8 gave me considerable more HP. Like 10-20 or so I forget right now, but can I do this? I'm sure my brother will know, as he will set the timing for me, but I was looking to get a faster answer. I thought you were supposed to advance the timing for more HP.
Old Aug 2, 2002 | 09:59 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
Outside timing is backwards, meaning that -8 on the bal is +8 on the motor I think. Meaning that you advance it +8 on the reading and it will give you -8 in the motor. Hope this helps.
Old Aug 2, 2002 | 10:03 PM
Car: 99 Formula
Axle/Gears: 342
OK. On DD2000 it says - is retarded and + is advanced.
Oops, it's showing 9 more HP at -8.
Old Aug 2, 2002 | 10:29 PM
Guest
Guest
Posts: n/a
9 upper end HP is not worth retarding the cam 8 degrees.
Old Aug 2, 2002 | 10:33 PM
Car: 99 Formula
Axle/Gears: 342
How far should I advance the timing then? And how much HP do you think I would get out of it?
Old Aug 2, 2002 | 11:10 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I think what you were playing with in DD2000 was cam timing. Thats the phasing of the cam relative to the crank. Advancing the cam opens the valves sooner, reatrding it opens it later. Advancing the cam usually builds more low end. Retarding it makes more power.
Thats what madmax was referring to, and that 8' of cam retard is pretty extreme.
Set ignition timing so it is consistent with best measured performance. You can't predict this value with a computer, or even by listening to other people. TnT is your friend
Old Aug 3, 2002 | 01:26 AM
Guest
Guest
Posts: n/a
I'd install it straight up or maybe a couple degrees advanced if your car is stock weight. It'll have soggy low end otherwise.
Old Aug 3, 2002 | 03:22 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
I think that all the cam manufacturers grind their cams so that installing it "straight up" actually results in the cam being 4 degrees advanced.
Why?
To provide some bottom end power without confusing newbies with the reason that they ground it that way.
Old Aug 3, 2002 | 06:23 AM
madmanups's Avatar
I say you leave the timing alone. My timing was advanced 4 degreees before and my car started to blow out white smoke at crank. I think it wears out teh valves too. Not worth it from my point of view.
Old Aug 3, 2002 | 07:13 AM
Car: 99 Formula
Axle/Gears: 342
Just noticed the timing was in the cam section of it, so thanks guys.
Old Aug 3, 2002 | 10:46 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Re: Timing, Is this Right?
DD2000 gets silly like that. The program has some quirks.
The cam I'm playing with in DD2000 (CC 8-305-8)will let me go to +/-14 and it makes a drastic difference. I'd never consider more that 4 one way or the other. If I thought the cam was lacking in the higher RPM area I'd retard it some, if I needed more down low I'd advance it some. But... never as far as DD2000 will let you go.
Old Aug 4, 2002 | 01:48 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Yes, you might gain 9+ hp at the peak by retarding the cam
that much from the stock timing but you'll give up too much midrange torque. Resulting in a net loss in performance.
It is best to install the cam as per the manufactures cam card
first, try it, then adjust from there. Usually if you need to actually move the cam by more than 8 degs, u need to select a different cam. Cam manufactures generally "grind in" some advance
in their designs. (4/5 deg) this has been found to result in the best overall torque curve and allows for some timing chain wear.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
