Drained My Oil, Did I mess UP??
Old Aug 6, 2002 | 12:36 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'm in the process of a cam swap. Almost done, just have to adjust the rockers. I drained my oil, so I can be ready to put new oil in. Now I was just thinking, the engine has to be bumped to adjust the rockers right? Is this ok, with no oil in the engine, I put about 1/2 qt of oil in the new filter.
Old Aug 6, 2002 | 12:51 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
you should just crank the engine by hand, take the spark plugs out to make it easy. The lack of oil shouldn't hurt for this, just use lots of cam lube!
ede's Avatar
ede
why don't you just put the oil in it now? you could always turn it by hand.
Old Aug 6, 2002 | 12:54 PM
Car: 99 Formula
Axle/Gears: 342
Yeah, I wasn't thinking. I still thought turning the engine by hand would cause metal against metal.
so, just pour the oil down the heads?, cause obvisouly the valve covers aren't on.
Old Aug 6, 2002 | 12:56 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
yes!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
ericjon262
Sep 11, 2015 06:07 PM
89 formula TPI
Sep 7, 2015 11:06 AM
