new cam, is this normal?
Old Aug 7, 2002 | 09:41 PM
SmokinZ28's Avatar
OK I just put a new cam in. It's a crane hydrolic lift cam. I dropped the distibuter in tonight. My question is when I turn the rotor a little it pushes the cam far enough up to hit the timing chain cover, is this normal? I don't have the rocker arms on so there's no actual load on any of the lobes. I put everything back in that came out also. This is my first cam swap :lala: so I figured I'd ask
thanks in advance
Old Aug 7, 2002 | 10:07 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
There's a slight angle on the cam lobes which forces the cam toward the back of the motor. An exception to this are roller camshafts which require a thrust button. Some put thrust buttons on regular cams for some 'extra' security but this is not required.
Old Aug 7, 2002 | 11:16 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Did replace the timing chain? Like already mentioned, flat tappet cams are ground so the lifters keep the camshaft in place. Turning the rotor with no lifters in place could cause the camshaft to move forward or backward but I'd think a new chain would have enough resistance to keep it from hitting, maybe not though.
Old Aug 8, 2002 | 07:48 AM
SmokinZ28's Avatar
Thanks guys. No I didn't replace the timing set, but it only has like 10K on it. It's a double roller and didn't appear to be streached at all so I figured it would be ok. I'll see what happens when I get the rocker arms tightened down so there's some pressure on the lifters
Old Aug 9, 2002 | 01:40 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
It'll be fine if it only has 10000 miles on it. Hardly even broke in
Jorlain
Oct 8, 2015 01:57 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
