Randomly occurring sound from engine...
Old Aug 7, 2002 | 11:01 PM
Matty377's Avatar
Car: '86 Camaro
Engine: LG4
Ok, i'm getting this odd sound from my engine. It's only when decelerating and sounds like a soft rapid tapping.
The only two times I've heard it were right after I :
1) flushed and filled coolant system and replaced plugs/wires
2) installed new radiator(today)
Now, the cooling system only took 8 quarts of water/coolant so I'm thinking the noise has something to do with the coolant circulation. It's a 305, I thought they had 17 qts of cooling system capacity. If this is normal, let me know. If not, I'd love to hear what is causing this.
Old Aug 8, 2002 | 11:57 AM
flyway190's Avatar
8 sounds about right
Old Aug 8, 2002 | 11:59 AM
Matty377's Avatar
Car: '86 Camaro
Engine: LG4
Thanks man, at least that's normal.
Anyone got any ideas on the engine noise?
Old Aug 8, 2002 | 12:12 PM
flyway190's Avatar
Does it do it every time you drive the car or only occasionally? Does it do it when you're idling at a stoplight?
Old Aug 8, 2002 | 12:48 PM
Matty377's Avatar
Car: '86 Camaro
Engine: LG4
Only occasionally makes the sound, and it's when decelerating to stop. This has only happened twice.
I'm pretty sure it kept making the noise at idle.
-Matt
Old Aug 8, 2002 | 01:35 PM
flyway190's Avatar
Next time it does it, put your emergency brake on and unplug your EGR solenoid to see if it stops. If that's not it, try to pinpoint where it's coming from by ear and by touch.
Fanatic1074
Oct 3, 2022 05:57 AM
tmellott89
Oct 14, 2015 02:06 PM
wanext
Oct 6, 2015 12:18 AM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
