oil in Throttle body ??????
Old Aug 8, 2002 | 10:54 PM
MrMike99's Avatar
what is up with this, I use 3-4 q a week and plugs are fouling. No external oil leaks, compression is good,. There is oil inside the throttle body, and it seems when the egr activates there is some oil smoke from exhaust. there is about 25K since rebuild and these are new problems. thanks
Old Aug 9, 2002 | 12:42 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
ummm... sratch that... The engine sounds like its taking in oil throught he breather or the pcv. Try replaceing the pcv and see if that helps. The engine will suck in fumes throught he breather. If the little filter there is black and oily, then thats probably the porblem.
Old Aug 9, 2002 | 01:31 AM
rezinn's Avatar
There should be oil in the throttle body.. not liquid oil though. Does it smoke when started? Or when you get on it? How is oil pressure? Have you changed your oil frequently? Ever let the engine overheat?
The egr recirculates exhaust into the intake to be burned again, so I couldn't see it causing oil consumption problems unless it was working the opposite and sucking gaseous oil from the intake into the exhaust. Losing that much oil has to be a mechanical problem, unless you're somehow driving 3000+ miles a week. How has the engine's life been?
Old Aug 9, 2002 | 12:45 PM
Car: 88 Camaro SC
Engine: SFI'd 350
abpout the only thing you should see in the tb is maybe a little bit of coking from the fumes picked up by the pcv/egr. Other than that the tb should be clean. Your obviously loosing alot of oil past the rings/vavle guid seals or some other part of the oil system. Oil all over the inside of the air cleaner/tb points more towards the valve guide seals letting alot of blowby spray the oil around.
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
