Reseting SES codes with fuses
Old Aug 10, 2002 | 04:48 AM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
Maybe it's a dumb question (no dumb questions just dumb answeres?) What fuse(s) do you yank to reset the codes..
Seems to me it would be a hell of a lot easier to do this than to disconnect the battery etc... I don't mind doing it but fuse seems way easier.
Someone posted about which is the burn-out relay for the MAF... and it was said it's the 1 closest to the fender by the firewall, is that the one closest to the firewall of the 2 that look alike? or the one closest to the firewall. I do notice that it has blue, black, 2 orange like in the instructions to check problems resulting from a 36 code. (When I get my tech manual, should be shortly, this will be easier). Then I gotta figure out how to get the damn things appart.
Old Aug 10, 2002 | 06:01 AM
ede's Avatar
ede
ought to be a large (red or black i think) wire coming off the + battery terminal along with the battery wire. the smaller wire ought to have a connection in it, take it apart for 20 seconds or so and that should reset the ecm.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
FormulasOnly
Jul 23, 2018 08:47 AM
thunder57
Nov 7, 2015 02:28 PM
okfoz
Oct 13, 2015 02:19 PM
lanceflame44
Sep 25, 2015 12:28 PM
