Camshaft end play?
Old Aug 10, 2002 | 08:14 PM
Z_Ghost's Avatar
Camshaft end play?
I put the cam in the block today and then put on the retainer, I can move the cam about .260” . Manual shows that it should be .004” to .012”, so can I just knock the rear plug in to get it were it should be.
Anything to watch out for when doing this?
92 305 roller cam block with a Comp cams roller cam.
Old Aug 11, 2002 | 07:13 AM
ede's Avatar
ede
i think you're checking it wrong. do you have the gear set and chane on it? don't drive the rear plug in deeper.
Old Aug 11, 2002 | 09:25 AM
Vader's Avatar
What does the retainer plate look like?
Old Aug 11, 2002 | 11:31 AM
Z_Ghost's Avatar
Ok I found out that I was checking it wrong, the service manual is a little confusing on it.
I put the gear on and it's right were it needs to be.
Vader I was talking about that plate that bolts to the front of the block and the nose of the cam sticks out of.
I am so embarrassed, but it is my first roller block and cam, thanks guys.
Old Aug 11, 2002 | 01:04 PM
ede's Avatar
ede
better to ask than break expensive parts
Old Aug 11, 2002 | 02:39 PM
Z_Ghost's Avatar
You got that right..
Old Aug 11, 2002 | 10:20 PM
Vader's Avatar
Thanks, but I know what the retainer plate is, and what it should look like. I should have phrased the question differently, such as: "In what condition is your retainer plate?"
Sorry I got lazy with the grammar...
Old Aug 12, 2002 | 01:07 AM
Z_Ghost's Avatar
Vader
Now I understand what you were asking as I was surprised that you asked that.
It looks like new, no wear from what I can see. It sits flat on my flat plate that we have at work so I know its not warped.
morrow
Jan 13, 2024 12:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
TheTraut88
Sep 11, 2015 05:16 AM
Stryker412
Sep 7, 2015 09:11 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
