What would happen if...
Old Aug 11, 2002 | 09:56 PM
92RSB4C's Avatar
I blocked off the purge canister? Mine's all fubared.Would it run any different?
Old Aug 11, 2002 | 10:17 PM
Ratstix's Avatar
if your talking abot the charcoal canister(which i believe you are)
take it off. get 2 feet of 5/16 tubing and run that from the hose that comes from the tank to under the car (mine is infront of the fender and ziptied up. the use a cap to plug off the port on the TB that the other hose was going to.
and as for the sensor thats plugged into it, cover it with electrical tape (so it dosen't get damaged) and tuck it away. you wont throw a code or anything.
BTW: why do you want to plug the line?
the only reason i got rid of mine is because it was an eyesore.
Old Aug 11, 2002 | 10:18 PM
Ratstix's Avatar
also if you need any more info on this, do a search (titles only) for charcoal canister. you should get all the answers you need.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
