putting in new ac compressor
Old Aug 12, 2002 | 03:54 PM
irocaz28's Avatar
Anyone got any tips/hints on putting a new ac compressor in. Im stickin wiht the r-12. I heard you have to know how much pressure in on the high side or low side something like that. any help will be very appreciated. And by the way its HOT AS HELL here in Jersey so please help quick!!!!!!!! THANKS
Old Aug 12, 2002 | 08:30 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
you could take the whole shebang out and leave it out
take the tops of for instant ac.
it saves oodles of weight.
matt
Old Aug 12, 2002 | 10:13 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
well to my knowledge if u take the compressor off u will have to get the R-12 recharged. if u look by that aluminum can there are lines comin off of it and on the lines there are black capas and uncer them are things that look liek tire stems and thats wut that are. wut i woudl do it wrap a towl around it and put a glove on and puch the pin n with a screw driver till the pressue stops comin out and do it to all the lines and u should be alright to take off the compressor. oh and by the way how much is a new compressor cause i need to get one also
Old Aug 13, 2002 | 11:52 AM
irocaz28's Avatar
i got mine for $100. I work at an auto parts store so i saved about $25. I also purchased a new accumulator and orfice tube. Had to get them to warranty the compressor.
SO does anyone know about the high or low side pressure?
Old Aug 13, 2002 | 11:57 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
You add coolant to the opening in the aluminum canister attached to the firewall.
It would be better to retrofit and go R134. R12 is horribly expensive and soon won't be available, period.
Old Aug 13, 2002 | 12:01 PM
irocaz28's Avatar
i "borrowed" 24 cans of r-12 so i got some reserve if i need it.
Old Aug 13, 2002 | 12:53 PM
82camaro's Avatar
Car: 82 camaro SC
The old school way to fill it(back when r12 was 89c a can) was to add freon until the compressor stops kicking in and out. If you have guages, fill until the low side is around 40 psi with the car running and compressor kicked-in.
evilstuie
Apr 14, 2016 08:52 PM
soarestransam
Sep 1, 2015 04:00 PM
TheExaminer
Aug 25, 2015 07:34 PM
rh76camaro
Aug 15, 2015 12:48 PM
Street Lethal
Aug 13, 2015 08:28 PM
