What oil dipstick will work?
Old Aug 14, 2002 | 08:38 AM
gtabadboy's Avatar
I got a new motor for my 88 trans am and now the dipstick is on the drivers side not the passenger side. My old dipstick will not fit in and I dont know what year the block is. It is a 1 piece rear main seal if that helps. What oil dipstick will work. I was thinking of going with the summit billit one.
Old Aug 14, 2002 | 09:51 AM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
Lokar Pre-1980 (I think?) flexible dipstick. Bolts to the headers and looks shiny and purty.
Old Aug 14, 2002 | 05:12 PM
83 MidniteZ's Avatar
Hmmm...one piece rear main with a driver side dipstick? Gotta look into that.
Old Aug 14, 2002 | 05:14 PM
Inwo, if it is indeed a one piece rear main than it would have to be 87 and up. Couldn't be pre-1980
Old Aug 14, 2002 | 08:35 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Mines an 87 block and its on the drivers side. Doesn't bolt on just pushes into the block. Actually I don't have a dipstick yet because I haven't been able to find one, but I know thats how and where it fits. Looks like I'll have to go to the dealer unless I want to order one.
Old Aug 15, 2002 | 07:21 PM
I just didn't think that any of the newer one-piece rear main blocks had the driver side dipstick.
Old Aug 15, 2002 | 11:41 PM
Nordbert's Avatar
What prevents you from using a chrome dipstick and tube for a
'79 and earlier 350? Does your car have cast iron manifolds which cover the hole in the deck of the block? I used an oil pan for
an '80-'85 block with passenger side dipstick and a block which
adapts the oil pan to the '79 and earlier 2-piece rear main seal block. This setup uses a long dipstick and tube like third gens.
The adapter block should fit the one-piece RMS block and pan,
too.
Old Aug 16, 2002 | 10:19 PM
killer305's Avatar
my stock dipstick wouldnt fit after my headers, so i got a locar one from summit, it seems they dont have it anynore
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
matthew911
Aug 12, 2015 09:38 AM
Leggman1
Aug 6, 2015 04:15 AM
