These Heads any good?
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
14096217...55-86...350..........Crate motor, 285hp/300hp, 64cc chambers,
72' or 90' center intake manifold bolt angles
with these upgrades. Looking to put them on the 327.
these are the 21 degree heads and have the 4 center bolt pattern for the valve covers.
the heads were rebuilt by a professional shop, and have:
5 angle valve grind
Crane valve springs with 110 pound seat pressure
Teflon valve seals
machined keepers
Tell me what ya think please!
5 angle valve grind
Teflon valve seals
machined keepers
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Yes they're good heads. Even better when ported.
Professional Products makes intake manifolds
that have a special center bolt adapter arrangement
that symplifies the center bolt angle issue.
If you'll be getting a new intake manifold, check these out.
They also cost less than the others.
http://www.professional-products.com/
Originally posted by Riley's35089rs+
I bought them for $270. So what will I have to do to swAP THEM ON THE 327? any info would be nice...
If you have the mechanical know-how to remove the top end, putting it back together with the new heads and intake will be self explanatory.
'Cept for the distributor alignment, but if you do a search, you will find in upwards of a hundred million threads on putting distributors in the right way.
Engine: 406
oh yeah, I know how to change the parts...just need to know, will the lifters and pushrods work that I have now? I think I will be installing a new cam at the same time, the current cam makes good power after around 2800rpm and Ive yet had it crap out at the top end..(old tranny lets loose first, new to be installed today) I just dont know the specs....roller tips would be nice also...any suggestions on a cam or other Items?
Ps The Distributer is no problem.
NinjaNife
Aug 23, 2015 11:49 AM
