5 shims to get starter to stop grinding
Old Aug 19, 2002 | 06:57 PM
breathment's Avatar
ok, installed a new starter on my friends 89 Camaro 2.8L ..
we took it off there were no shims.. so i figured, hmm maybe we won't need to add any. so i installed it. turned the key. and GRRRRRRRRRRRRRIIIIIIIINNNNNNNNNDDDDDDDDDd the engine didn't even turn over.. it just made an awfull grounding noise. so i went out and brought shims, and started adding them.. well 5 shims (.25") later, it was at a acceptable position. it would start but there was still a little grinding noise.. This doesn't seem normal that it needs a 1/4 inch of shims to get it to not grind. am i doing somethign wrong..
Old Aug 20, 2002 | 12:17 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
sounds like maybe you go the wrong starter, we put a starter on my buddies 2.8l blazer,(starter was from autozone), and if i recall, we used no shims, maybe one thin one at most
Old Aug 20, 2002 | 06:29 AM
ede's Avatar
ede
never heard of needing that many shims. you might want to try shimming one hole, i ithnk the inner, to move the starter away from the flywheel/flexpalte. i'd double check too to make sure they sold me the right starter, but if it looked the same and bolts up very good chance they did.
sahlomonic
Sep 20, 2015 07:15 PM
Denricci22
Sep 18, 2015 09:02 AM
dimented24x7
Sep 17, 2015 06:58 AM
Cleotiz
Sep 16, 2015 08:02 AM
Formula_88AE
Sep 3, 2015 01:47 PM
