Problem with heads on new 350
Old Aug 21, 2002 | 11:08 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Okay I just got a mild 355. I have already run into a problem and the engine is still on the stand! The problem is with the accessory holes in the heads. Here is the picture of the front of the engine. If you can't see it the front of the drivers side head has 3 accessory holes in it and the front of the passenger's side head has 1 bolt hole in it. Here is a picture of the back of the engine. The back side of the driver's side head has 1 bolt hole and the back side of the passenger's side head has 3 bolt holes. This means that no matter what I will only have 1 accessory bolt hole on the front of the passenger side head. The heads casting numbers are 3998993. Could I drill and tap a hole in this head? Is it even necessary since my accessory bracket uses 4 mounts, two of which are in the block and one already has a hole in the head; so I would only be missing one mount. Plus there is the brace that goes to the intake and the brace that goes to the header. So can I drill and tap, ignore the one missing bolt hole(actually two), or take off these heads and throw them in the trash can(I hope not, $ is very tight)?
Thanks,
Brady
Old Aug 21, 2002 | 11:17 PM
I should add this isnt a new engine, I think it is a 1972 block.
Old Aug 22, 2002 | 12:53 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
What you have is the standard small block head setup.
Old Aug 22, 2002 | 07:14 AM
ede's Avatar
ede
yeah what sitting bull said, what's the problem, that's how gm wanted it to be and how they made all the brackets to work.
Old Aug 22, 2002 | 07:49 AM
i know. i will check again but i am pretty sure that the passeners side bracket for the AC compressor and smog pump uses TWO mounts in the head.
Old Aug 22, 2002 | 08:40 PM
ttt
Old Aug 22, 2002 | 09:38 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
That can't possibly be true cause his serpentine brakcets use 2 bolts into the head on the passenger side which is where his question comes in.
Re: Problem with heads on new 350
ttt
Old Aug 22, 2002 | 09:55 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
examaple of Vortecs
Old Aug 22, 2002 | 11:14 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
if the passenger side bracket is all one piece like it was on my buddies 89 4.3 blazer, and has 4 or more bolts holding it on, you can do without one of them, as long as one goes into the head you'll be ok.
we swapped engines in the blazer, it only has 2 bolts holding the passenger bracket on cuz some of the bolts grew legs and ran away, and we were on a tight schedule, he has no i'll effects, more than 10k miles later
Old Aug 23, 2002 | 03:24 PM
thanks for the reply
Jake_92RS
Jan 28, 2020 10:37 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
