changing balancer after balancing.....
Old Aug 22, 2002 | 08:55 PM
Fast3rdGen's Avatar
an interesting point came up in a discussion among me and the other gear heads i work with........if you build a motor for street use and get it balanced and what not.......if you go to enter dragraces with it and they require an sfi cert. balancer......do you have to have your rotating assymble rebalanced???? even if you buy a balancer that has the same balancing as the motor (internal/external)???? for the first time a question has come up that no-body in our lil group knew the answer to.
Rich
Old Aug 23, 2002 | 05:30 AM
ede's Avatar
ede
it's not a hard question to answer, i say no you don't. were you wanting the correct answer or just an answer?
Old Aug 23, 2002 | 06:22 AM
Fast3rdGen's Avatar
why would i want anything but the correct answer?
Old Aug 23, 2002 | 07:03 AM
ede's Avatar
ede
correct answers cost more since a lot of times they require more thought. incorrect answeres require no thought at all. smartass answeres often require more thought than correct and incorrect answers combined.
Old Aug 23, 2002 | 07:11 AM
82camaro's Avatar
Car: 82 camaro SC
If you replace it with a balancer that is exactly the same, except it's certified, then the balance will be the same.
Old Aug 23, 2002 | 07:38 AM
Fast3rdGen's Avatar
now if only all people could give such a simple, straight to the point answer such as this.
Old Aug 23, 2002 | 08:11 AM
ede's Avatar
ede
ain't that what i said to start with? " no you don't"
Old Aug 23, 2002 | 10:39 AM
Damon's Avatar
If it's a standard neutral-balance piece coming off and it is truly neutral balanced AND the one you are putting on is a neutral balanced piece and is also truly neutral balanced, then no. Please note, however, that I have heard of some shops that drill out the back of the balancer as part of the balancing process if there isn't enough beef left in the crank. Really rare (and not good practice), but just FYI.
However, if you are running a 383 or 400 using the "offset balanced" 400-style balancer then the answer will usually be YES. Why? The balance of these pieces often varies significantly from manufacturer to manufacturer, so finding 2 totally different balancers with exactly the same balance would be a small stroke of luck.
Old Aug 25, 2002 | 12:08 AM
Rancid87's Avatar
Actually, ede, the only question you could probably give a straight answer to is the current location of your head. Which is most likely because it's still shoved up your ***.
Old Aug 25, 2002 | 11:08 AM
Fast3rdGen's Avatar
finally......a spot light is turned on instead of a candle lit.
midge54
Dec 27, 2019 04:14 PM
C409
Sep 23, 2015 04:30 PM
Americanmouse
Sep 7, 2015 12:10 PM
gixxer92
Sep 1, 2015 04:32 PM
Linson
Aug 31, 2015 04:52 PM
