How do you determine what heat range plug to use?
Old Aug 27, 2002 | 10:54 PM
GTA400SBC's Avatar
how do you know what type(heat range) of spark plug to use?
Im ready to fire up my 400 but i don't know what Plug to get for it.
the cam i'm using is the Lunati Bracket Master 2 in summit it's specs are:230 degree/230 degree duration@.050",.480"/.480" lift
I'm also running a Weiand single plan intake a Holley 650 DP i will be running pump gas factory ignition (for now). any help will be great. Thanks in advance....
Tommy
Old Aug 27, 2002 | 11:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's almost trial and error since so many things can affect the plug temperature. What works good in one engine might not be best for another. Try a cold plug like R43TS. If it fouls up too much then go hotter with R44TS. The plug temperature range is the actual temperature of the plug. The goal is to have the tip of the plug between 450* and 850*.
Go to the Calgary Drag Racing Association web page. Click on Tech Tips then click on Spark Plugs.
Old Aug 27, 2002 | 11:10 PM
ede's Avatar
ede
it's a lot like guessing. actually i start with a couple of steps colder than factory and see how it does. there is some good info here on plugs that may help you.
http://www.calgarydragracing.ab.ca/
Old Aug 28, 2002 | 06:48 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
i guess stephen is talking centgrade
i always heard min 800 degrees cold and like 1500 hot. One that does not foul during cold start and does not contribute to detonation at operating temps and normal ignition timing.
Old Aug 28, 2002 | 08:21 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Like Stephen suggested, a 43 is usually a good place to start. The number he gave you is for tapered-seat plug holes in the heads; make sure what kind of holes your heads have, and get the right seat type to go with it. Post what heads you have, maybe someone can tell what plug type to use, then you have to do the experimenting with heat ranges.
Old Aug 28, 2002 | 10:32 PM
AlkyIROC's Avatar
Car: 87 IROC L98
http://www.acdelco.com/html/pi_plugs_ident.htm
I always recommend the extended tip plugs. It gets the tip just a little bit farther into the combustion chamber to ignite the air/fuel.
Old Aug 28, 2002 | 11:55 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
A good article on "reading" plugs.
http://www.nightrider.com/biketech/readplugs.htm
Old Aug 29, 2002 | 12:28 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
The guys pretty much covered it. If you start with too hot a plug you risk engine damage from preignition. Start cold and if they foul, move to a hotter plug til you get a light tan color on the insulator. Tapered/motor seat plugs are usually found in cast iron heads and gasket seat plugs are in aluminum.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
db057
Sep 4, 2015 07:57 AM
86IROC112
Aug 21, 2015 07:20 PM
