jumping the starter solenoid question
Old Sep 4, 2002 | 07:55 PM
IceBlue91z28's Avatar
Car: 1991 Camaro Z28
Transmission: Built 700r4
what on the solenoid do I touch together to get my car to start because the key wont turn it on but the vats is ok i think the key lock cylinder is bad. I just need to know what to touch together with a screwdriver...thanks
Old Sep 4, 2002 | 08:29 PM
quick_90's Avatar
IF im not mistakend, you should touch the starter cable(pos battery cable at the starter) to the ignition wire (purple most the time). it is a post on the selinoid just cross with the screw driver.
does it click, when you turn the key? if it does, its a washer in the selinoid that needs to be replaced. hope that helps and if anyone has some other than that feel free.
quick_90
Old Sep 4, 2002 | 09:55 PM
it doesnt even click anymore it just does nothing. Thanks for the help
Old Sep 5, 2002 | 08:17 PM
quick_90's Avatar
did it work??
Old Sep 5, 2002 | 10:29 PM
didnt try it yet doing it saturday mornin when i go home
Old Sep 6, 2002 | 05:10 PM
gtabadboy's Avatar
All you have to do is jump the two posts on your starter. One is the heavy red live battery cable and the other is a purple (color may vary) wire that is connected to the small post of the starter. Heres a couple of articles on how to wire it. I had the same problem. Before rewiring. Get a test light ground it and touch it to the small post on the starter. Have someone turn the key all the way forward. If it lights up then the wiring is not the problem and it may be a faulty selenoid or various other problems. If it doesnt light up try running a new wire. I posted how to do it. Good Luck
https://www.thirdgen.org/techbb2/sho...hreadid=103057
fasteddi
Sep 2, 2015 10:29 AM
Accerrito22
Aug 23, 2015 07:22 PM
Cleotiz
Aug 22, 2015 01:54 PM
redmaroz
Aug 16, 2015 11:40 PM
