Port flow ratings and cam lift question...
Old Sep 5, 2002 | 07:28 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Say I have a head that intake flows 239 cfm @ .500 lift, and 229 @ .500 lift.
Do I want a cam that has under, over or exactly .500 lift? Generally speaking...
Old Sep 5, 2002 | 08:25 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
What head is it? Give me a lot of specs on what you got and I can run if on DD2000 FWIW.
AJ
Old Sep 5, 2002 | 09:19 PM
rezinn's Avatar
I don't get the question. How could it flow two different numbers at the same lift?
Old Sep 5, 2002 | 09:32 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
probably a typeo
but.. get one with the most agressive lobe you can at the max lift.
in otherwords, find the cam with the shortest duration at the max flow number
__________________
89rs w/a 400, some aluminum things and a 4.10 gear
Old Sep 5, 2002 | 10:41 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
My mistake...it should be 239 cfm @ .500 lift, and 229 @ .600 lift.
I found these specs for the 855 casting Vortec head. I have the 062's but I figured they'd be about the same.
I have DTD2000 and I've been trying different cams. Seems like I make the most power in the RPM range I want with the cam I already have. I just need to add 1.6 ratio rockers for more lift.
I remember someone saying that you want .060" clearance from retainer to valve guide for safety. I measured .511" from open until the retainer touched the guide. If I plan on having .481 lift that leaves .030" clearance. Maybe I could try a set of Comp or Crane retainers? Any thoughts? My cam specs are in the signature, it's .431/.451 lift.
Thanks for the replies...
Old Sep 7, 2002 | 03:37 AM
Car: Bee-Bowdy
Axle/Gears: fo-tins
ttt
Old Sep 7, 2002 | 11:08 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Flow never goes down from opening the valves further, unless you use undercut valves and you open them so far that the non-undercut section ends up in the port. So beyond a purely theoretical question, don't worry about it ever happening to you. Those specs are in error; just like you won't reduce the flow of 2 pieces of 1/2" garden hose by replacing one of them with a section of 1" hose.
The numbers given on cam cards are peak lift numbers. The valve actually spends very little of its time at anywhere near that lift. Don't try to evaluate flow that way. A hypothetical cam with very steep ramps that snaps the valve instantly open to .400" and holds them there would outflow a cam with typical gentle street profiles and .550" of peak lift. It's "area under the curve" that counts. That's why the newer designs of cams like Comp's Xtreme series are so much better than older designs: they used computer modeling methods to design ramps with the maximum "intensity" possible while keeping the valve acceleration below the threshold of beating the valve train to death in a short time.
Old Sep 7, 2002 | 05:32 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Select a cam based on it's .050" timing specs and intended rpm range. Not peak lift. Leave the design up to the cam grinders.
There is more to it than numbers and ,more is usually not better.
All the cam manufactures have tech lines and tech email to help you select your next cam. They are the experts on their stuff
and want you to get the right cam the first time. It's in their best interest. Give 'em a call.
Old Sep 8, 2002 | 10:01 AM
Vader's Avatar
Originally posted by RB83L69
Flow never goes down from opening the valves further...
...they used computer modeling methods to design ramps with the maximum "intensity" possible while keeping the valve acceleration below the threshold of beating the valve train to death in a short time.
Yeah, I was confused by that, too. And thanks for referencing the acceleration rate of the valve train. I thought that maybe I was the only one who ever considered that, or at least tried to discuss it. That's always important when designing the valve train, or especially when considering springs, and one of the main reasons factory springs aren't acceptable for use with almost any aftermarket cam.
Old Sep 8, 2002 | 10:21 PM
84camarojs's Avatar
AJ
Can you run these through dtd2000
Old Sep 8, 2002 | 11:52 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Here it is.
Old Sep 9, 2002 | 12:56 PM
84camarojs's Avatar
the heads have 2.02\1.60 valves, but its still pretty good
Old Sep 9, 2002 | 05:36 PM
Engine: 305-4v
They'd progressively add 10 or 15 hp to the top end of the curve. So around 355 hp. Good motor!
Old Sep 9, 2002 | 06:37 PM
84camarojs's Avatar
what with 1.6 magnum rockers and a 625 demon carb
LT1Formula
20
Nov 14, 2015 12:02 AM
formula_novice
Sep 5, 2015 03:58 AM
tmellott89
Aug 16, 2015 02:58 PM
happyhapka
Aug 15, 2015 04:42 PM
355tpipickup
Aug 13, 2015 07:35 AM
