weird idling
Old Sep 6, 2002 | 11:55 PM
primer84z's Avatar
weird idling
when my car it idles and drives fine. once it warms up, the idles wont drop down like they are supposed too unless you pop the gas. but when i take off with light throttle, it opens on its own and speeds up to like 1500 with out me hitting the gas and it wont come down from there unless i pop the gas pedal. whats goin on? its a 600 edelbrock electric choke. didnt start doing this until after cam swap.
Old Sep 7, 2002 | 10:40 AM
Vader's Avatar
Check for binding in the throttle linkages, cables, etc. Also check the choke bimetallic spring adjustment and vacuum operated pull off (if equipped), high idle cam, and choke linkages.
gta892000
Aug 11, 2019 11:16 AM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
