do i need a new prom with auto to t-56 swap?
Old Sep 7, 2002 | 09:21 PM
breathment's Avatar
i know that with the stock chip it the ECM will try to lock up the T.Q. and might throw a trouble code. but i read something somewhere that I might have a rough idle because of incorrect readings from the VSS or something like that. i don't mind the check engine light if it is only for the T.Q. not being there. but i don't wanna drive it if it will idle rough until i get it fixed..
Old Sep 7, 2002 | 10:20 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Opps... didnt see you had a 5.7L, i dont think they made proms for the 5.7L with a manual t-5 but i could be wrong. The vss deal does seem to have some validity to it. The computer seems to open the iac to smooth the transition from part to closed throttle under braking untill the car comes to a stop.
Old Sep 8, 2002 | 12:01 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
FWIW, a girl I used to date had a '91 Z28 auto and sold the chip to a guy that had a '92 Z28 5 spd. He didn't have a lik of trouble, ever. No codes, no rough idle, nothin.
I know his ECM didn't have the means for a TC lockup since his car never had one, but I would think that's all controlled by the chip.
AJ
Azrael91966669
25
Jun 20, 2017 04:04 AM
Keith5
Aug 27, 2015 04:37 PM
Hello, Michael
Aug 20, 2015 03:19 PM
Sanjay
Aug 12, 2015 03:41 PM
cRoe4
Aug 7, 2015 08:46 PM
