zz4 cam
Old Sep 7, 2002 | 10:03 PM
radiateu2's Avatar
zz4 cam
would a cam from a zz4 engine fit a 1987 305 with 4bbl carb I will be switching to a non cc carb
Old Sep 8, 2002 | 12:43 AM
jimmy_mac's Avatar
It should as long as your 87 block is machined for the roller cam. There will be three bosses tapped in the middle of the lifter valley and two holes drilled at the front of the block behind the cam gear.
I am assuming you don't have the LB9 with roller cam so to use the factory roller system with the zz4 cam you would have to get the factory hydraulic lifters with the hold down bars and the spider to hold them in place. That's what the tapped bosses are for.
I have seen the whole set-up sell on e-bay for anywhere from 50 to 100 dollars. Or you could probably use aftermarket retro fit lifters with link bars but I am not 100% sure on that.
Also it would probably be a good idea to get the springs recommended for the zz4 cam from gm. I don't think they are to expensive. Check out this site for prices. https://www.spoperformanceparts.com/
Old Sep 8, 2002 | 05:20 AM
radiateu2's Avatar
zz4 cam
my block is a roller block I was wondering how the zz4 cam would perform in a 305with ported heads. Does anyone have a clue. Does anyone have the specs on the zz4 cam and is it compatible to a crane or comp cam and if anyone knows which cam it is compatible with. Thanks
Old Sep 8, 2002 | 08:36 AM
Lionsden's Avatar
GM's ZZ4 cam (GM part # 10185071)
This dual-pattern profile has .474" intake lift and .510" exhaust lift. Intake duration is 208 degrees (at .050" tappet lift), and exhaust duration is 221 degrees
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Magman
Sep 13, 2015 12:14 AM
masonta
Sep 1, 2015 06:40 PM
