Not a Thirdgen but a good question.
I have a 2001 Biuck Regal with just a plain 3.8 motor.I wanted to put a open element on it,but when I took out the air filter assembly I discovered what looks like a computer.
Is this a computer?What would be a cheap way to convert this to an open element and protect this computer without buying some kit that may cost some big bucks?
Car: 89 Formula Firebird
Engine: 305 - Demon 525
2001 Regal ? Have you got a pic of that motor. I'll find one on the net if I can but an open element on a 2001? Hell I guess anything is possible.
Is this it? And is this the type of air filter you want?
<img src=http://www.knpowersports.com/Images/filters/kart/kart_2_1_16th_flange.jpg>
<img src=http://206.117.169.65/RoadTests/BuickRegalGS/Images/Engine-med.jpg>
Guest
Posts: n/a
A computer?
What you probably saw is part of the mass air sensor. Theres probably also an air temp sensor in there somewhere.
I wouldnt run an open element. Just get a better flowing air filter, and remove any air silencer they probably have on the side of the filter away from the engine side.
Thats a mighty big sensor.
It is as big as my computer in my Firebird.Thanks for the pics Redbird and that's what I want.It's just that big sensor I'm worried about.I want to know what to do with it if I take that filter assembly out or do you have to relocate it.
It is as big as my computer in my Firebird.Thanks for the pics Redbird and that's what I want.It's just that big sensor I'm worried about.I want to know what to do with it if I take that filter assembly out or do you have to relocate it. Trending Topics
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Originally posted by madmax
Interesting... I wasnt aware that they were putting computers under the hood like Dodge was. Never seen GM do that besides the Corvette.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I'm not sure about the Regal GS, but since it's the same engine and body platform as the Grand Prix, then it's in the air cleaner box.
I read an article in Pontiac Performers or Pontiac Performance, or something like that and they did a build up of one of those S/C 3.8's. The air cleaner kit they bought came with a special seperate box to put the ECM in to protect it from the elements.
I thought it was strange to see it under the hood, but to put it in the air cleaner box? I guess the inlet for the box brings in cool, outside air, so it would keep the ECM cooler, right? Especially on those -20* days here in IL.
AJ
AJ
NBrehm
Aug 25, 2015 11:49 PM
