help i ran over new paint on road now its on my car...
Old Sep 10, 2002 | 04:19 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
how do i get it off please help..
Old Sep 10, 2002 | 04:27 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
do you have a buffer? I had to use one when the business across the street got paint on my buddies 98 Z28, "our paint couldnt have done that, it turns into dust when it hits the air" So then how did all of this "dust" stick to his car so well?!?
Anyways, We just washed it and then used the buffer on it and it went away, and looks really nice.
Brian
Old Sep 10, 2002 | 04:37 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it's like blobs and not a mist, try a plastic razor blade.
Old Sep 10, 2002 | 06:10 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If the paint on your car is Base/Clear (most 86 and newer, or repainted) use either laquer thinners
or Urethane reducer (Clear coat reducer)
If your car has laquer paint (older factory paint) then use
enamel reducer or auto solv (wax and grease remover)
Keep the car out of the sun so the oversprayed paint doesn't bake in.
Once this paint overspray is "cured" you will have to buff it off with
a fairly course cut compound and a buffing machine.
You can try sanding with 1200 wet and polishing if it's is clear coat.
If your car was waxed or had a pertectant applied before,
the paint should come off with solvent. as above.
Test a small hidden area first. If the solvent on a cloth is picking up paint, (your car paint) then don't use it.
Wash your car with soap and water first so you don't rub the dirt into your paint.
You'll want to use two rags. One to wet the car paint with the solvent and one to wipe it clean.
You'll need lots of clean cloth rags or kimtowels.
Old Sep 10, 2002 | 08:54 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Take some Dawn soap to the car. Then use a clay bar, if the above mentioneds fail.
Old Sep 10, 2002 | 08:58 PM
Vader's Avatar
Wait until it dries, then flick it off with your fingernail.
You DO keep wax/sealant on the car body, DON'T you?
Old Sep 10, 2002 | 09:08 PM
Car: 99 Formula
Axle/Gears: 342
If he doesn't, I'm sure he'll get an ear full from us.
Old Sep 10, 2002 | 09:46 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
yea i do. i got most off on one side by taking it off with my finger nail. but then i though i was scratching the paint. BTW what is a clay bar. i went and asked autozone and they looked at me stupid
. and for my paint it is not the orginal paint so i dunno what to do about the solvents. if i just go buy a buffer will it take off the paint.
Old Sep 11, 2002 | 06:03 AM
Sciguyjim's Avatar
I would be very careful with a buffer. Examine the paint that you have gotten off and see if it has any reflective particles in it or sandy particles for grip. If it does and you buff, you'll ruin all the surrounding paint. I'd first try some of the solvents mentioned on a rag with light wiping and dabbing at the spots.
Old Sep 11, 2002 | 05:51 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
i used the clay bar and it didnt work. so if i flick it off with my finger nail it scrates the paint. i have no clue what to do.
Old Sep 11, 2002 | 07:51 PM
cjboeke's Avatar
go to any auto part store and ask for a clay bar, it is essentially that. At the same time I know Kragen sells stuff that is made for road paint. Also, if all else fails i used a product called goof off (get it at home depot) and it took it off for me, but mines not factory paint so be carefull with it.
Old Sep 11, 2002 | 09:14 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
Just buying one won't take the paint off. You must use the buffer also. :sillylol:
:hail:IROC-Z
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Winchester1094
Aug 18, 2015 10:23 AM
NufNuffZ28
Aug 14, 2015 09:12 AM
