ported LT1 intake pictures
Old Sep 13, 2002 | 06:38 PM
Odyssey's Avatar
I received my LT1 intake a couple of days ago from John. I wanted to post some pictures of it ported and gasket matched to a FelPro 1206 gasket. I know a lot of people said you can't open them up too much, but there's still plenty of room to go even after porting for a 1206 gasket! Here's some pictures.
Old Sep 13, 2002 | 06:39 PM
Odyssey's Avatar
Some more...
Old Sep 13, 2002 | 06:40 PM
Odyssey's Avatar
And the intake itself
Old Sep 13, 2002 | 08:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
How did you locate the distributor hole? I've stared at those things before, just knowing there was a hole down in there somewhere, but I couldn't find it....
Kind of like Michelangelo, he loved sculpture more than painting; he said the statue was just waiting inside the stone, all the sculptor had to do was expose it.
Old Sep 13, 2002 | 08:11 PM
Odyssey's Avatar
Hehe... well like I said.. i just received it from John. You know... the LT1 intake ***.. www.lt1intake.com. He did write an article about it. Read it and try what he did ! I gave him 200 bucks to it. For me it was well worth it.
Old Sep 13, 2002 | 08:15 PM
JR305's Avatar
So are you putting it on the 406 in you sig? If so how much do you think the swap will cost you? I have been thinking of putting an LT1 intake on my car.
Old Sep 13, 2002 | 08:29 PM
Vader's Avatar
Yes, they can be opened quite a bit and still madee to match the heads, provided you enlarge the openings on the heads as well...
Old Sep 13, 2002 | 08:34 PM
rezinn's Avatar
RB,
I looked at how John did it and actually made something to locate the hole myself one day. Basically you just form a piece of sheet metal to the bottom of the stock tpi intake, drill holes in the sides for bolt holes, and bolt it to the intake. Then you just remove the material where the distributor hole is. I have a semi-expensive drill bit made to make the exact size hole. I think it is about 1 3/4" in diameter. After cutting the hole all you need to do is bolt your sheet metal piece to the LT1 intake from below and you've located it.
Getting the distributor to sit correctly on the LT1 intake is another story, but John has that covered as well.
Old Sep 14, 2002 | 05:35 AM
Odyssey's Avatar
Yeah, I have a set of pro action heads fully ported to go with it Yes this setup will go on the 406. All I hope for is that I get low 11s. I'm tired of tuning the carb and getting horrible gas mileage. Here's a shot of the intake ports on the heads.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Fast355
Dec 2, 2016 06:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Jake_92RS
Aug 11, 2015 10:39 AM
