What Heads to look for?
Car: 99 Formula
Axle/Gears: 342
What casting # heads are good, I think I've seen 916, 882 and others on ebay.
Saw some Vette al heads goin for $500 right now, but prolly will go up.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Pull off a valve cover and check the casting # on your heads.
Then go to www.mortec.com and have a looky at the head casting # info list.
You'll find that your have large chamber 76cc smog heads.
Your motor has very low compression. all of the other large chamber (76cc) heads like 882's etc will not help you.
You'd best look for some 58 to 64 cc heads.
A set of Vortecs would really wake that motor up.
About your best bang for the buck.
Get a set and a matching manifold and do the required mod
and then bolt them on. You won't be dissapointed.
You would want to install them with a thin .015" "shim head gasket" to maximize your final cr with your non blueprinted dish piston motor. (exessive deck clearance)
Car: 99 Formula
Axle/Gears: 342
try looking in to some World Sportsman IIs...if you have the money they are GREAT heads...they will work with your intake...
they have 2.02 intake and 1.6 exhaust...and a little porting will make these bad boys flow...
My motor is at a performance shop right now getting built up...with the heads cam and intake and forged pistons ill be running around 400hp...
DABE
DABE
Car: 99 Formula
Axle/Gears: 342
DABE
DABE
ed's 1le?...haha...
Welp...they are GREAT heads...too bad that they are cast iron...you can get some bowties or some of the vette alum. heads from sdpc2000.com...
How much are you looking to spend?...you can always port and polish your heads that you have now get them flowing more...i have a set of 305 heads if you are interested in them...
DABE
DABE
Car: 99 Formula
Axle/Gears: 342
I can't spend more than $500. So, I"m on a tight budget. I know of some that I can get for that brand new, just not sure of the brand, I have to find out. Ed's are cast iron huh?? that's ok, just means they will be cheaper so that I might be able to afford them.
My heads now are 76cc and I want to get around 10:1 compression.
the world heads bare (no valves and stuff) you can score them for around 300 bucks a side jegs
You should buy the heads bare so you can use the correct valvesprings ans stuff with your new cam...
they say the heads can add about 50-100 hp...right out of the box...i dont know if that is true...but they will increase your power a lot...whats the rpm range of your intake...is it a dual plane high rise??
I think you would be better off with the sportsman IIs...get the 64cc chambers and you should be where u want to be...ill be running a forged JE piston with the 64cc heads and ill have about a 10.3:1 compression ratio (my motor is being blueprinted and balanced and decked....
If you save up a couple hundred more you would be set...valves and stuff arnt that expensive...
I would try to stay away from the 1.94/1.5 intake heads...you will choke your 350....2.02/1.6 is a good all around street head....
If you have any questions please feel free to ask.... ive talked to u before on IM (DabeWhatRYaDoin)
DABE
DABE
Car: 99 Formula
Axle/Gears: 342
Yeah, I want 2.02/1.6s. I already have comp springs to match my cam, but then valves will be $160 plus $50 for locks and retainers. So that would be $800 a little more than I want to spend. Guess, for now I'll wait and see what kind of heads the ones I'm lookin at are. I'm waiting for my brother to email me back about them.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Vortecs are the best bang for the buck even including the new intake manifold. You can't get good aftermarket heads for under a grand, and there's no stock head that comes close. The L98 d-port aluminum corvette heads are pretty good heads, and when ported properly can rival AFRs, but paying somebody with the talent to do them right (aka lingenfelter) will cost as much as AFRs anyway)
Get vortecs, get a new intake, and recoupe some of your money by selling your current intake on Ebay.
Car: 99 Formula
Axle/Gears: 342
Guess I'll wait to hear back from my bro about those other heads. But how bad could they really be, being brand new 2.02/1.6 64cc heads? for $500.
welp...u never know...let us know what brand and model they are...
Before you buy them...see if you can take them to a machineshop and have them check the heads for warpage...thats one thing you dont want...warped heads...even tho they are new they could be damaged in some way...also they are probally cast iron...the alum. are a lot more $...
DABE
DABE
if i recall the vortecs dont have the 2.02 intake and 1.6 exhaust valves that he is looking for.....i looked in to the L98s....they would choke a 350....
DABE
DABE
Hell... Lingenfelter used those heads on his 420 cubic inch motors.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
