bouncing tach over 3500
Old Sep 17, 2002 | 10:13 PM
laiky's Avatar
problems problems problems
I just rebuilt my distributor, new GM pickup, accell modual and coil, cap rotor and gear.
ran fine for a while, ran it up to 6000 great feels better than the original did, idles better too. today on my way home from work i rev past 3500 and the tach starts bouncing all over the place, up down at least 1000 rpm , it sfine under 3500 though.
any ideas???
Old Sep 19, 2002 | 09:38 AM
Vader's Avatar
Go back to your project and check all the connections at the coil and HEI module - especially the grounds. Also check the connections (grounding) of the little condenser-looking device in the distributor base. My guess is that the Accel amplifier/switch module is switching higher voltage than the tach filter can tolerate, but that's just a guess.
Old Sep 19, 2002 | 10:12 AM
laiky's Avatar
actualy it didn't do it yesterday or today, i think it may be a bad ground though, that on my list for this weekend
Old Sep 19, 2002 | 11:23 AM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
Too much timing advance might cause this also.
$750 L98
Feb 1, 2025 02:25 PM
Eric-86sc
Sep 28, 2015 11:37 AM
tuningnewb
Sep 23, 2015 07:06 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
