Update: Found Out why my track times were horrible...
Old Sep 20, 2002 | 01:29 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
As some may know before I left for college I took the car to the track after my cam/intake mods. Well, my first run was 16.22 and 2nd run was 15.49, my car was running kind of warm 230* on the first run.
Well, I had my brother take a look at a few things while I left for college. Turns out, the timing was off, and 2 plug wires weren't hooked up to the distributor that well, just kind of laying on the cap tips (those bronze things). How that happened I have no idea.
So, maybe a 15.49 run on 6 cylinders and timing off wasn't too bad.
Old Sep 20, 2002 | 06:43 PM
rezinn's Avatar
Come on Mark, it's hard to believe you couldn't tell your car wasn't running on all 8 What was your mph on those runs?
Old Sep 20, 2002 | 06:50 PM
Car: 99 Formula
Axle/Gears: 342
84 adn 89 mph.
My brother said they were on there good enough, that some spark should have made it thru the wire, but still I don't think it would be as strong as it could be.
Old Sep 20, 2002 | 08:57 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
What all did you do in the pits between runs? look at the engine?
the track is the perfect place to try different things to fine tune your engine (timing, jetting, fuel pressure, shift points, valve lash, etc)
get with it man!
don't forget to check your thottle linkage too.. I had mine stick at 75% for a while
Old Sep 20, 2002 | 09:12 PM
Car: 99 Formula
Axle/Gears: 342
I had no tools with me and he wasn't there. I figured it was running fine. guess not.
Old Sep 21, 2002 | 12:34 AM
darbleinad's Avatar
Car: 84 Trans Am
you ran a 15.49 with all your mods, including a good cam and you thought it was running fine????????
good ***
why dont you actually do some work on your car.
my LG4 ran 15.32, and it has the same compression as your motor (8.5:1) and stock, unported 305 heads.
Old Sep 21, 2002 | 11:14 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
89 MPH should be good for high 14's atleast. Something was definately wrong.
Old Sep 21, 2002 | 08:12 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
Who goes to a racing event with no tools!?!?
Old Sep 21, 2002 | 08:22 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
i might have u beat with poor performance
my 400 only made 319hp at 5200 on the dynojet.
torque was 384. And in the process of rejetting, the "technician" stripped the fuel bowl threads on the main body.
Old Sep 21, 2002 | 08:24 PM
Car: 99 Formula
Axle/Gears: 342
Well, new wires on , plugs cleaned up. Timing set properly. Well, it still feels slow to me.
Old Sep 21, 2002 | 08:41 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Mark,
What was your 60'. I know that with a cam as big as the one you have and the the compression your motors got, that you've got a bad vacuum signal. this is why your torque is suffering. The cam is bleeding off all what little compression you've got at lower rpms. I bet you have real ****ty throttle response and when you rev it, it struggles to get to 5k.
Also check for a vacuum leak. Spray some carb cleaner around the manifold and see how the idle reacts to it. Did you install the cam straight up or is it retarded or advanced?
BTW-to those a**holes who know everything-Jer82Z28, darbleinad! This site is not meant for malicious criticism but rather informing and helping others with problems. Unless its helpful how about just not posting. darb-WOW.....you have a mid 15 sec 305...now thats cookin . Since your such a wise mechanic how about telling him WHY his car might be running so slow and HOW he could fix it. Jer-not everyone brings tools to the track.....why you ask............cause tools are heavy. And whats the rule of thumb about weight. DUUUHHHH.
Old Sep 21, 2002 | 08:49 PM
Car: 99 Formula
Axle/Gears: 342
Originally posted by No4NJunk
Mark,
My 60' times were like 2.333 or so. Terrible I know. The cam I believe was done straight up.
Oh yeah, the throttle response sucks. And it doesn'tt rev to freely.
Oh yeah also, sometimes if I punch it, the car will hesitate then take off.
Thanks for that comment too, I'm really bad at working on cars, it's just somethign I'm not good at, some people are mechanically inclined, I however am not. I'm good at others things, that some people aren't but I don't go around damn why don't you....
Old Sep 21, 2002 | 10:16 PM
darbleinad's Avatar
Car: 84 Trans Am
first of all i didnt say i have a fast 305, its not fast, its a 15 second car, which is not fast. and also i always take my tools to the track with me, but i never leave them in the car when i run. i just leave them in the pits.
as for what may be wrong....first of all make sure the timing is correct. you will likely want something in the area of 10-12 degrees base timing. you motor should be able to handle a fair amount of timing with the 8.5:1 compression. then i would look at your spark plugs, are they a nice tan colour or are they fouled or kinda like a whitish/grey (running lean), etc? your carb may need to be rejeted/richer metering rods (do edelbrock use both jets and metering rods or what...i am not really sure) to ensure the carb is feeding the motor enough fuel. to avoid bogging, you will want to make sure your secondaries are opening at the appropraite time (not too early and also you dont want them to open too late either as the motor will be starving for fuel). as NO4N Junk mentioned, that is a fairly good sized cam and maybe too big for your low compression motor and/or your torque convertor. do you have the stock convertor, cause if you do a high stall one maybe required.
Old Sep 21, 2002 | 10:24 PM
Car: 99 Formula
Axle/Gears: 342
It's a stock TC but from what I don't know. It was given to me when I got the tranny rebuilt.
My brother checked the plugs after the car idled for about 10 mins, and said they were clean, so it was running lean. But, he wasn't sure if that would be long enough to run it, so I'll take a look at the plug tomorrow, if I get a chance, I'm goin back to college.
I drove it up to our meet today, so that was about 150 miles on it. Damn thing took all my gas though on the trip.
Old Sep 21, 2002 | 11:08 PM
johnyIROC's Avatar
Check the plugs immediately after a WOT pass.
Old Sep 22, 2002 | 02:17 AM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
Mark,
Well I guess you straightened me out :sillylol:
Some things in life require common sense.
How are we REALLY supposed to help someone diagnose a problem when he can't even verify whether his engine is running like it should?
If you don't know how, learn.
How do you expect to get the most out of your car when you refuse to try different things between runs?
Will you be happy when it just runs "ok"?
How does your brother 'know' what the timing should be at without actually testing it?
NOT tuning your car while racing at the track is an opportunity lost IMO.
no malicious critisicm intended, but here's a thought...
before racing, take your tools out to save weight..
but for the love of all Fbodies, take some tools with you!!!!
Old Sep 22, 2002 | 08:17 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Mark, have you checked total timing? Make sure you check this and bring it all in around 2500rpm. Shoot for around 36 degrees. Your car should not feel slow at all!
Old Sep 22, 2002 | 08:45 AM
Car: 99 Formula
Axle/Gears: 342
OK, so bring the rpms up to 2500 right, and how do I tell if it's 36*. I know there is a timing tab down there, but does it go up to 36? See, told you I'm not good with this stuff. Also, for that I still plug off the vacuum line to the dist.?
Old Sep 22, 2002 | 10:42 AM
MetKiss316's Avatar
Dude, your still running 8.5 comp with the mods you've got?
Boy, wait till you get them new heads:lala:
Old Sep 22, 2002 | 10:50 AM
Car: 99 Formula
Axle/Gears: 342
Yeah I know.
Oh yeah, guys, my brother did check the timing by bringing the rpms up to 2500 or so.
Old Sep 22, 2002 | 03:20 PM
No4NJunk's Avatar
Boy that was just soooo funny.
COMMON SENSE!! read that comment again. He obviously CAN verify his engine isn't running right or he wouldn't have posted would he.
I don't know where you race but where I do there is no where to just take out your tools. If you just leave them somewhere chances are they'll disappear. I'm not rich enough yet to have my own designated pit area!!!
Old Sep 22, 2002 | 03:31 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
hey mark check these out...you were looking at heads right?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1860092823
Old Sep 22, 2002 | 03:48 PM
Car: 91 RS
Engine: 350 TBI
Re: i might have u beat with poor performance
Try this one on for size. My last project had a 460 in it. I had this thing dipped and cleaned out and rebuilt. I put about $4,000 into this motor, basis of the package being the total Edelbrock Performer package. That bitch only dynoed at 218 HP and 335 lb/ft.
I'm talking, I did everything to it....Holley 750, Edelbrock Performer package, Ford Motorsport roller rockers, Holley high-volume fuel pump, Summit high-volume oil pickup, MSD ignition ( I mean the whole thing to ), TCI Saturday Night torque converter, I think there was more, but I forget.
And to top it all off, when it was on the dyno, I spun a bearing!
P.S.- Does anyone want to buy it from me? If your mechanically inclined, it should only be about $700 in parts to fix it. Everything else is perfect w/ the car. 1972 Lincoln Mark IV
^shameless plug^
Old Sep 22, 2002 | 08:24 PM
Car: 99 Formula
Axle/Gears: 342
How would I know if they're good though as in not fu(ked up.?
Old Sep 24, 2002 | 12:58 AM
johnyIROC's Avatar
Re: Re: i might have u beat with poor performance
Originally posted by Gunny Highway
Ford Motorsp....
Found the problem!
Old Sep 24, 2002 | 01:04 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
You can't tell.
Get F-Bird's heads or I'll have to come down there and swat you
Old Sep 24, 2002 | 04:11 AM
Engine: 406
Mark, I just wanted you to see the price range of the heads your brothers friend has..I think $500.oo is too much...these are going at a good price. As far as are they good? You have to check out peoples feedback...dishonest sellers do not stay on E-bay long. Ive had good luck with used parts...new parts are a different story. You E-mail the seller, ask them questions, you can weed out the BS...three hours left..$151.00
Old Sep 24, 2002 | 05:51 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hell, a few guys at Englishtown lost tools, and they were in their own pit area! I've always wanted to go with a car that wasn't racing, though... to throw my spare tire and etc in their trunk, along with an air tank..
Azrael91966669
25
Jun 20, 2017 04:04 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
