Pics Of My Plugs
Old Sep 22, 2002 | 09:38 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Pics Of My Plugs
Here is a pic of my #1 plug after about 150 miles on it, and several WOT times.
1st pic is blurry, let me get anotehr one.
Old Sep 22, 2002 | 09:42 AM
Car: 99 Formula
Axle/Gears: 342
I don't think i can get a clearer image with this camera.
Old Sep 22, 2002 | 11:14 AM
TBI305Camaro's Avatar
Ok from the pic I cant tell if thats good or bad. I wish I had a digi cam to show you the plugs I pulled. They were pretty nasty.
Old Sep 22, 2002 | 11:19 AM
heres the worst one. It was in #8 which I believe had the worst valve seals. Damn thats a clear picture from a webcam. You cant tell buy the electrode is toast.
Old Sep 22, 2002 | 11:27 AM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
That IS a clear web cam picture. Wish mine was that clear. Lucky bastard.
:hail:IROC-Z
Old Sep 22, 2002 | 11:33 AM
It so clear you can see the grease underneath my fingernails! And the cut on my finger from something under my hood. I never come out from under that hood without cuts all over my hands.
Old Sep 23, 2002 | 09:16 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
mark, do you have a macro on your camera? it should be a picture of a flower by a button, if you have it, it makes upclose pictures clear and distant ones fuzzy. from what i can see your insulator is still white so you're not fouling out too bad
Old Sep 23, 2002 | 01:41 PM
rezinn's Avatar
Put your spark plugs on the ground and then take a picture, or project light on them from behind the camera. More visibility = better. My webcam takes perfectly clear pictures if I focus it.
Old Sep 23, 2002 | 01:47 PM
Car: 99 Formula
Axle/Gears: 342
I'm back up at college now, so I can't.
Old Sep 23, 2002 | 02:47 PM
Damon's Avatar
First thing I'll suggest is that you stop using Bosch Platinum plugs. I and many others have had bad expereinces with them (weird premature plug death, and high RPM miss). Take that for what it's worth. I recommend using dirt-cheap $1.25 Autolites.
Is the black mark on the electrode only on one side?
Is there a lot of oil on the plug threads?
Old Sep 23, 2002 | 10:42 PM
If your talking about mine yes. The electrode is burnt bad on one side. Yes there is alot of oil on it also. That one came from #8 which Im assuming had the worst valve seals out of all my plugs. The seals are fixed now so Im hoping I dont foul my new accel plugs.
Old Sep 23, 2002 | 10:57 PM
Car: 99 Formula
Axle/Gears: 342
Yeah, those aren't mine. i don't run platinum anymore.
Old Sep 24, 2002 | 05:47 AM
me neither I have accel U-groove "header" plugs. They were pretty convenient actually. Made it alot easier to get the socket on them because they are pretty short.
Old Sep 24, 2002 | 04:11 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I am running Bosch Platinums, and would love to get rid of them. What other plugs can I use that are 3/4" lenght?
THanks,
Old Sep 24, 2002 | 04:19 PM
rezinn's Avatar
I see nothing wrong with bosch platinum plugs, they're fine in my car and short enough to clear my headers well. I've been running them for well over a year now. I ran ran ac delcos, champion, and even autolite plugs a couple times before that.
Old Sep 24, 2002 | 06:40 PM
With my bosch platinums I have trouble getting a spark plug socket on them because of my hooker headers. With the accel "header" plugs its easy. I figured out that its easier to just use the socket and a 19mm open end wrench to do my plugs.
Old Sep 24, 2002 | 07:35 PM
BAK12484's Avatar
heh, i laugh at you guys who think you have bad plugs . This is the one pulled from cylinder #3... still haven't gotten around to putting new valve seals in it yet (hope its that and not rings).
Old Sep 24, 2002 | 09:05 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
YUK! That looks like something that would come out of this things ***.
Old Sep 24, 2002 | 11:12 PM
Oh damn Im not sure which is scarier that plug or whatever the hell that thing is. Did your car run with plugs like that? Mine ran bad and missed at low RPMs the way mine was.
evilstuie
Feb 28, 2016 03:33 PM
Bryan F
Aug 27, 2015 07:28 AM
BurlyChev
Aug 22, 2015 01:52 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
cstrobel65
Aug 15, 2015 10:19 AM
