Car is starvin - Need Help
Old Sep 23, 2002 | 04:43 PM
nooneytunes's Avatar
Car is starving to death - don't think it's a fuel pump problem as it starts "sometimes" ?? After starting it will stay running - keep in mind I'm new to the car enthusiast arena please - Turns over fine - just can't get it to start up every time, when it does, starts on the first turn - - Was recommended that this could be the fuel system relay switch - Can anyone be so kind as to tell me where this relay switch is located and how difficult it is to replace? Fuel pump's gonna be a expens job, trying to troubleshoot other possibilities before I take it in for a replace. Was also recommended that this is a sensor problem that might be fixed by disconnecting and reconnecting the battery to see of the sensors re-set themselves. I'm a babe among wolves, not sure where to go from here!! Thanks.
Old Sep 23, 2002 | 05:21 PM
WideOpenVTwin's Avatar
Car: 1992 Camaro RS
Engine: 355
Axle/Gears: 3.73:1
I'm not sure which fuel system you have, but on my TBI I had the same problem. The relay was located by the firewall on the passanger side. You can't miss it, it's a large relay and i think there may even be a label near it. All u do is unplug it and plug in a new one.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
