Tachometer Problem
Old Sep 27, 2002 | 08:44 PM
phil37's Avatar
Tachometer Problem
I have a '88 2.8 V6 MPFI Camaro. My tachometer stays on 5000 rpm. When i turn the ignition on it goes up to about 5500 rpm. I turn the ignition off again and it goes back to 5000 rpm, all without starting the engine....... Anyone any ideas. .
Old Sep 27, 2002 | 09:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's broken.
Get another one. There's plenty of 6-cyl tachs for these cars at junkyards.
Old Sep 27, 2002 | 09:34 PM
phil37's Avatar
Tachometer Problem
Thanks.... Not many 6 Cylinder's here in England ( most are Z28's), will probably have to order one from the U.S.......
Old Sep 28, 2002 | 08:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Ahhh.... didn't realize you were across the pond...
Those are pretty common in the boneyards here. Try this link
http://www.car-part.com/
Old Sep 28, 2002 | 08:34 AM
Spifz's Avatar
Car: 1986 Z28 / 2012 CLS550
Engine: F-1R -> Aluminum block 540
Transmission: T56 Magnum + GForce gears
Axle/Gears: Ford 9" 3.00's + Eaton Truetrac
You got one of those cheater black boxes hooked up to your tach so you can run your dial in at the drag strip, don't ya?
Old Sep 28, 2002 | 07:46 PM
phil37's Avatar
Tach Problem
Thanks RB83L69, i'll check it out..........
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
