Interesting fuel pump problem.....see inside!
Old Sep 29, 2002 | 02:35 PM
84 Challenge's Avatar
Just replaced the fuel pump on my 84 Iron Duke Camaro. Bought this car back in may and it appears every wire, hose, nut & bolt has been messed at one time or another during it's life. Like I said, replaced the fuel pump. Car still would not start. Dropped the tank again to check connections. The new pump was connected the same way as the old. I looked under one the tail lights & found a cut wire that feeds into the fuel pump. Alright.....re-connected the wire. Now I can hear that infamous "hmmm" sound from the new pump. One problem.....it makes that sound after you try to start the car instead of before. In other words....no hmmm sound when the ignition is turned on. Only after I attempt to start her up. Weird!!! Now....how to fix??? What could cause this, another wiring problem? I take it the pump is connected right. The red wire leads to the + post and another faded red (no black wire) wire with a white line feeds the - post. Does this sound correct? Any help would be appreciated. Sorry for the long post.
Thanks,
Brandon
Old Sep 29, 2002 | 06:25 PM
After searching the board for a while, seems the pump is fine. Most likely the problem is a wire issue. Found a pinkish looking wire connected directly to the battery with some sort of link. Does this power the fuel pump? I disconnected the wire and had no effect on the pump as it acts now.
Brandon
Old Sep 29, 2002 | 07:34 PM
JOHN/88IROCZ's Avatar
The link you are refering to might be a fusible link and it might be blown. Take a test light and make sure you have power on the side going to the pump. Hope this helps, John
Old Sep 29, 2002 | 07:37 PM
How do you tell if it's fusable? It's really nothing more than two wires connected with a fancy connector?
Brandon
Old Sep 29, 2002 | 07:41 PM
The ones I have seen are black or clearish looking and about 1/2 to 3/4 of an inch long and about 3 times bigger around than the wire.
Old Sep 29, 2002 | 09:18 PM
This one's black. Opened it up and didn't see anything in there to replace. Tomorrow I'll rip all the fuel pump related wiring to inspect.
Brandon
Old Sep 29, 2002 | 09:50 PM
long&low's Avatar
Car: 88 ext.longbed 1/2 ton
Engine: TPI 350
Transmission: Slushbox 400
How about a bad fuel pump relay?
Old Sep 29, 2002 | 09:59 PM
Already replaced the relay. Can someone explain to me what a fuseable link looks like and what exactly it is?
Thanks,
Brandon
Old Sep 29, 2002 | 10:34 PM
Rage13's Avatar
Car: 89 Firebird
i belive they are about 3/4" long, black, and aprox. 3 times thicker then the wire.. and they are just an inline fuse (seems like a dumb thing to have to me, a fuse you have to cut out of the line to replace..) i found one on my starter wire and cut it off after the wires shorted and caught fire, guess mine didn't work to well anyway..
Old Sep 30, 2002 | 10:28 AM
I found it! Took it apart and seems fine. How can you tell if it's bad?
Brandon
Old Sep 30, 2002 | 04:15 PM
Rage13's Avatar
Car: 89 Firebird
try using it to light a low volt light bulb (with battery of course ) if it lights up, the link should be good
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
