what size is the crank snout bolt on a 400?
Old Sep 29, 2002 | 08:24 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
The one off my 350 crank doesn't fit. It's too big. I am going to get one tomorrow. I need to know length and threads per inch and width. Thanks in advance.
Old Sep 29, 2002 | 09:30 PM
Vader's Avatar
Wow. I would have guessed a 7/16-20 x 2", just like most other small blocks. I don't get close to the unbalanced cranks too often, so I'm not sure...
Old Sep 29, 2002 | 10:28 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I thought that the 350 one would work, also. I took it out and tried to put it in. No luck. I'd say that 20 threads would be the same and the length but I put a 3/8 bolt up there and it slid right in without screwing it in. So does this mean it could be 13/32"? This seems crazy. Do I have some oddball crank?
Old Sep 30, 2002 | 12:33 AM
Vader's Avatar
If you have a 7/16-20 tap, you might try cleaning up the threads in the 400 crank snout. If you encounter excessive resistance, you may have an odd thread, but the next nominal size over 3/8 is 7/16. A 10mm would be slightly larger than 3/8", but shouldn't exist in the nose of an SBC crank.
Old Sep 30, 2002 | 07:03 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It is 7/16"-20, no question about it. Same as any other SBC that has a bolt.
Sounds to me like your crank threads need some work.
Old Sep 30, 2002 | 08:50 AM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
or maybe they already have had some work done to them?
Old Sep 30, 2002 | 08:57 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Possibly... in which case it needs to be undone, and re-done correctly.
Old Sep 30, 2002 | 11:24 AM
Vader's Avatar
Good point. I have had to re-tap the threads to 1/2-20 to save a crank after some careless attempts at hub installation. However, that would make the standard bolt just slide right in. If the 7/16 won't start, chances are the threads are bunged a bit.
If you do get a replacement bolt, make certain it is at least a grade 5, and preferably a grade 8.
Old Sep 30, 2002 | 09:03 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I got a 7/16-20 tap and ran it through. It barely went in for all the rust. I had to keep going back and forth to get the rust out of the snout. I took a 7/16-20 bolt and put it in no problem. This engine had been sitting outside upside down for several years. It was really rusted up. Thanks for the help guys. Before the tap there would have been no way the bolt would go in.
Old Sep 30, 2002 | 09:20 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
i ended up having to re-tap the crank in my 305 to a 1/2 inch bolt with 20 thread.
tried to turn the engine over by the snout bolt. stripped the threads right out.
toronto formula
Nov 10, 2015 06:17 AM
camaro71633
Sep 1, 2015 10:24 AM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
knight72
Aug 10, 2015 09:32 PM
