Timing chain cover...
Old Oct 1, 2002 | 11:18 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
On a 89 305.. Where should the timing tab be?
At the 12 o'clock position or offset arround the 2 o'clock position?
Kat
Old Oct 1, 2002 | 11:53 AM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
There's really only one place where it will line up to the dampener. I'd have to say that would be closer to your "two oclock" position though.
Old Oct 1, 2002 | 11:55 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Thats what I thought..
Kat
Old Oct 6, 2008 | 03:36 PM
SpeedyGeek's Avatar
Car: 87 Formula
Engine: BluePrint 355 w/ 600cfm Carb
Axle/Gears: New axles, Yukon 3.73 & Eaton Posi
Re: Timing chain cover...
Did you put this on in the 2 o'clock position? Did it work for you? I have a 90 305 I need to put a tab on.
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
