Going to the Junkyard on Sat, what should I get?
Car: 1991 RS
Engine: 305 TBI
The U Wrench It where I live is having a grand opening sale on Sat. Anything you can carry, $29.99.
What valuable, possibly overlooked stuff should I be on the lookout for? I'm bringing my friend from school who works out every day, cause I'm not sure what they mean by "carry."
Any suggestions?
Thanks,
Homer
P.S. How do I tell a th400 from a 350 or 700? And a 400 sbc has two freeze plugs per side instead of 3, right?
Any suggestions?
Thanks,
Homer
Car: 4
Engine: 6
Transmission: 5
A 400 has a pan shaped kind of like an oven mitt, or like Texas. The others have square pans.
Nearly all small blocks have 2 freeze plugs in the side of the block. A 4-bolt (early) 400 has 3. They quit doing that about the time they quit using 4-bolt caps in them, but not all at once; a few with 4-bolt caps have only 2, and a few 2-bolt ones have 3.
Any part of one of these cars is worth money. A non-AC heater box would be worthwhile; any rear end from 90 up cars, especially with disk brakes; etc.
Think of things that are worn out on your car. Everybody else's the same things are worn out too. If you see ones that aren't worn out, get them.
Car: 1991 RS
Engine: 305 TBI
What's that webpage where you can buy stuff from junkyards across the country? That'd be good for some price checking.
Car: 1991 RS
Engine: 305 TBI
ECM's! I haven't even thought of that! What cars are those 747, 730, and 165 in? What should I take with them, wiring harnesses and whatnot?
165 is in 85/86 - 89 TPI cars.
730 is in 90-92 TPI cars. And also in late 80's V6 F-bodies, Cavaliers, lots of different models. An F-body wiring harness could sell for a lot on Ebay, since that is the best to use for a port fuel injection setup.
747 is in 87-92 astro vans, pickups, it's the truck TBI. A full wiring harness and ECM is very desirable because a lot of guys use it to convert their old cars to TBI style fuel injection.
746 is the F-body TBI, also quite useful.
LOL, how much time do you have to spend at the junkyard, you could make a lot of money.
HoosierinWA
Oct 7, 2015 10:15 AM
I'm j/k.
