1-piece valves in stock Vortecs...
Old Oct 6, 2002 | 04:00 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Would it even be worth my time (and money) to replace the stock valves in the Vortec heads with aftermarket valves? Undercut, or swirl polished...something like that.
Old Oct 6, 2002 | 06:35 AM
ede's Avatar
ede
lot depents on how much jack you have to drop and how you define worth it. if i were going to do it i'd buy manely valves with the reduced stem and swirl polish. you get a better valve and more flow. you can also go with a 3 or 5 angle valve job, or just undercut the back side of the valve 30*. you'd want ported heads and all the other tricks if you do this i'd think or you wouldn't realize all the gains you could have.
Old Oct 6, 2002 | 07:27 AM
Vader's Avatar
Then again, if you wanted to increase the valve face size, you'd have to get different valves. Like Ed says, the Manley Race-Flos are a good valve at a good price. Typically the larger diameter valves weigh less than the smaller stock valves, so you get the advantage of a lighter valve train as well.
Old Oct 6, 2002 | 12:55 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
If it'll flow better with a reduced stem and a swirl polished face then it's worth it to me.
I don't want to take the heads off once I get 'em on so I want to do all this now.
gta90
Sep 15, 2015 04:00 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
mustangman65_79
Aug 8, 2015 01:18 AM
