Swirl port head casting numbers?
Old Oct 8, 2002 | 04:56 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Does anyone here know the casting numbers for the "swirl port" heads used on the '87-later L05?
Old Oct 8, 2002 | 05:03 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
1986-88 14102191 350 1.94 1.5001 - EFI, swirl port
1986-88 14102193 350 1.94 1.5001 - EFI
1986-91 10110810 305 1.84 1.5001 - EFI,swirl port, stat wgn
1986-91 14101081 305 1.84 1.5001 - EFI, std port
1988-93 14102188 350 1.94 1.5001 - EFI, swirl port
1986-91 14102187 305 1.84 1.5001 - EFI, swirl port
I don't know if that's all of them though. Maybe you can cross-reference them at www.mortec.com to find out more info on them.
AJ
Old Oct 8, 2002 | 05:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Do you suppose somebody could make a "voodoo head" with those numbers on it, maybe the 305 ones too, so we could stck a few pins in tehm now and then?
Old Oct 8, 2002 | 06:42 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Wow. I'm going to save that list just 'cause. Thanks!
RB83L69, I suppose I could take an intake valve out and run a length of rope thru the intake port and out the bowl area. Tie the rope in a knot and you'd have one heck of a boat anchor!
LT1Formula
20
Nov 14, 2015 12:02 AM
MoJoe
Sep 24, 2015 09:12 PM
camaro71633
Sep 1, 2015 10:24 AM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
