Used Head gaskets ...Overheat?
Old Oct 10, 2002 | 09:27 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Hi i have a stupid question
i have a friend witha 2.8 bird and he has used the same head gaskets for 3 times ...he rebulided the engine and put the same HG on it กกกกกกกก
what a sucker กก
this cause overheating ??....his car now overheats and he told me that it cant be the used H/G ...what you think ???
whatcan cause a used head gasket ?
i think he is dealin with his engine life ก
please answer me i will print your answers and show him
Old Oct 10, 2002 | 11:11 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
First, it is never a good idea to use a used head gasket. Once the head has been removed, the gasket usually sticks to the head or the block. It would take a lot of care to get it off without damaging it.
Second, the only way that I think it would cause over heating is because it's letting water go into the oil pan, or out the engine. Once there is enough coolant gone, of course the engine will overheat.
Other than that, I don't know of another way it would cause over heating. Not that I can think of now.
AJ
Old Oct 11, 2002 | 02:39 AM
Kevin Johnson's Avatar
Re-using a head gasket could cause overheating if the high pressure combustion gases are leaking into the coolant (bad sealing). You can buy a kit to check for the presence of these gases in the coolant. I would not be at all surprised if this happened.
Some head gaskets are designed so that re-use is possible (maybe not the optimum plan, though). Solid copper head gaskets, for example. Yes, you would need to be very careful removing them.
Old Oct 11, 2002 | 04:01 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Yea, what he said. The combustion/compression will leak into the coolant and the pressure in the radiator will skyrocket. Some people say you can tell because there will be bubbles in the radiator. Or you can use a pressure tester on the radiator. Regular pressure won't go much over 15psi. I saw this situation on a buddy's car that had blown a head gasket. As soon as he'd start the car, coolant would shoot out of the radiator like a gyhser if the cap wasnt on. If it was on, the car would start to overheat in about 5 minutes flat.
IMO you should never re-use a head gasket after it has been compressed.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
