AC delete question
Old Oct 13, 2002 | 09:37 PM
Nasty_Bird_'90's Avatar
AC delete question
In the proces of pulling out the AC. I pulled out all the lines/hoses along with the canister. Can I pull out the big black box on the firewall, or does that have something to do with the heater?
Old Oct 13, 2002 | 09:51 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yes, that has the blower motor for your heat. What I did, was cut that box in half, if you want, my brother made a custom delete box that you can buy. Try a search on the tech board for my pics of it I posted. I just haven't had time to put it on myself.
Old Oct 14, 2002 | 08:50 AM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Part of it containes a condensor and part a blower motor. Like mark siad just cut it in half and cover the hole or buy a box out of a car that didn't come with ac.
Old Oct 14, 2002 | 08:52 AM
Car: 99 Formula
Axle/Gears: 342
If you cover the hole and I assume you mean just block it off, then he will have no heat.
TBI305Camaro's Avatar
a buddy of mine totalled his s15...it had a non AC box which i wanted off of it but insurance took the truck before I had a chance to snag it
With a non AC box it looks so much better. Also allows ALOT more room to do plugs and header bolts. I cant wait to get a non AC box and a AC delete pulley.
Old Oct 14, 2002 | 11:28 AM
No4NJunk's Avatar
Well funny you say that! You would think that in the winter without the fan motor, or the box that it would get pretty cold huh. Not the case for me. My damn engine compartment contains so much damn heat it was enough to get through that hole and sweat me out. LOL, I was the only moron going down the road with the windows open in 30 degree weather. Can you imagine what it would have been like for me in the summer!!??
Old Oct 14, 2002 | 12:36 PM
Car: 99 Formula
Axle/Gears: 342
What I mainly mean is, defrost is a must. Specially in the winter or sometimes when it rains out.
Old Oct 14, 2002 | 02:04 PM
No4NJunk's Avatar
the radiator fan pushed enough air through to get into the duct and flow out the defrost for me!! Don't know if thats the case with anyone else.
Old Oct 14, 2002 | 06:10 PM
I've been trying to find a way to rig the pulley up somehow to aviod gettting an a/c delete pulley, but haven't figgered it out yet . Has anyone done anything else other than a delete pulley, or is that the only way? Where do i get one? Mark, can your brother make me one of those boxes you gave me the link too?
Old Oct 14, 2002 | 07:16 PM
Car: 99 Formula
Axle/Gears: 342
Next time I talk to him if I don't before I go home this weekend I will.
Old Oct 16, 2002 | 09:12 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Dare I ask why you are hacking your A/C out?
Old Oct 16, 2002 | 09:18 PM
Car: 99 Formula
Axle/Gears: 342
Room clearance, perhaps.
Old Oct 16, 2002 | 09:32 PM
kid camaro's Avatar
Car: 91 z28
Engine: 305 tpi
a/c is a waste. thats what t-tops are for hehe
Old Oct 17, 2002 | 07:58 AM
hey whats up eric.
1, more room
2, looks cleaner
3, easier to work on (especially plugs and headers)
4, I never use(d) it! Always take the ttops out.
Old Dec 6, 2002 | 03:02 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Mark My conversion to right-hand drive meant that some idiot put the steering post right thru the lower right hand corner of the heater box. Wasnt sealed properly and I was wondering if I could only block of that section of the box with some Armaflex or insulating material? Would I have enough room working from the inside of the box given that the evap. is there? There is a lot of cool air escaping from around the shaft. (lower right means facing the heater box from the front of the car) Saw on your post about your brother cutting the box in half and thought that you might know. Thanks
Old Dec 6, 2002 | 04:58 PM
Fredzep's Avatar
Car: 90 GTA
Transmission: TKO
Axle/Gears: Stock
AC delete Pulley GM Part #10115875
You can get it at http://www.gmpartsdirect.com/
Frozer!!!
Jan 19, 2024 04:55 PM
Out-Cast
Aug 22, 2015 07:49 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
redmaroz
Aug 16, 2015 11:40 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
