if i buy a 350 ci block with my tpi am i gonna run like a l98?(14.6 stock?
Old Oct 14, 2002 | 06:17 PM
cridom's Avatar
Old Oct 14, 2002 | 06:32 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
HUH!!??? What are you asking? 350...running like an l98?? If you get an l98 it will. LOL. if its just a crate 350 then....no it won't. I guess thats what your asking .
Old Oct 14, 2002 | 06:39 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Your setup compared to an L98..
it deoends on ur specs.. compression.. heads..cam...
Old Oct 14, 2002 | 07:11 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
exactly
Old Oct 14, 2002 | 08:10 PM
cridom's Avatar
what if i put a l98 cam on my 305?
Old Oct 14, 2002 | 08:18 PM
pauldaniel26's Avatar
Car: 1986 IROC-Z28
Engine: 355 in the works...
You will still be missing 45 cubes and better heads.
Old Oct 14, 2002 | 08:53 PM
cridom's Avatar
my goal is to kill n e 95-98 mustang and ricers do i need to get a 350????????????? or can i just mod my 305?
Old Oct 14, 2002 | 09:17 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Headers, which you just got.
Cat-back
3:42 gears
higher stall TC like a 2200 or so.
That should get you low 14s. And it will all be there later if you want a 350.
Old Oct 14, 2002 | 09:31 PM
cridom's Avatar
btw marks i bought the 5fth pair of slps that summit had w/y pipe and tomorrow sfcs. so how much are gears and stall?????????
what brands thanks..
btw how much hp are slps gonna give me with the y pipe?
Old Oct 14, 2002 | 09:37 PM
Car: 99 Formula
Axle/Gears: 342
I'd say an estimate of 20hp for the headers and y.
Gears, Richmond, $200 and install kit of $100. Though gears are tricky to install, plan on spending $200 or so to get them done for labor.
A TC is around $3-400 or so.
Old Oct 14, 2002 | 10:39 PM
MdFormula350's Avatar
use what you got untill it breaks then upgrade engines..
like Mark said, gears would help alot of the line, and also a stall converter...
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
NBrehm
Aug 25, 2015 11:49 PM
