Weird Vacuume readings
Old Oct 14, 2002 | 07:32 PM
Tranny Man's Avatar
I am having some problems w/ my 88 TBI 305. I have an odd hesitation under load.I put my snap-on scanner on it and it showed a MAP reading that looked backwards very low at IDLE but climbs to 22-25" at part throttle and if I try to pull a hill the knock sensor comes on and the powers goes way down. Also the clear flood indicater is on I checked the vacuum line and found it to be repaired but I think it may have been put on the wrong port of the throttle body Any help??? Keith
Old Oct 16, 2002 | 08:41 PM
Tranny Man's Avatar
bump
Old Oct 17, 2002 | 06:08 AM
Vader's Avatar
If you're getting a "clear flood" flag, you probably should check the TPS.
Old Oct 17, 2002 | 06:10 PM
Tranny Man's Avatar
Vader by flag do you mean as I'm driving the clear flood line reads yes? Because it does but the tps signal looks good? Maybe I will switch it out anyway THANKYOU Keith
Ghettobird52
Jul 5, 2024 11:18 PM
Cleotiz
Jan 6, 2018 08:56 PM
mdtoren
Aug 23, 2015 12:52 PM
CORV3TT3
Aug 23, 2015 11:26 AM
mdtoren
Aug 16, 2015 05:45 PM
