block leak
Old Oct 21, 2002 | 08:27 AM
9-FIREBIRD-2's Avatar
Old Oct 21, 2002 | 09:42 AM
ede's Avatar
ede
clean the spot and dye check it, you can buy dye check kits from welding supplys. if you have porosity in the castings super glue or epory will fix it. welding would be another option but i don't think welding would be my first pick. way back when i worked on cars for a living i fixed several casting flaws with something very simialr if not the same as super glue the the manufacturer recommended and supplied
Old Oct 21, 2002 | 09:49 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it's below the drain plug, it might just be that the plug is leaking... if so, take it out with a 6-point impact socket, and replace it with a brass one... use about 5 or 6 wraps of Teflon tape on it, do not use silicone.
Old Oct 21, 2002 | 09:51 AM
block leak
it is past the plug, toward the tranny. about 1 inch past the plug
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
Loudnproud86
Jul 14, 2016 12:59 AM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
