Can you use a non roller cam and lifters in a roller block? Why not?
Old Oct 21, 2002 | 08:14 PM
Hulk0202's Avatar
Just curious what the diffrence is. I hate putting all that extra money in my 305. I know....used lt1 cam. Anybody selling one?
Old Oct 21, 2002 | 09:12 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Yes.
Old Oct 22, 2002 | 03:08 PM
Hulk0202's Avatar
Anything a little more in depth? Will there be any problems? What about pushrod length?
Old Oct 22, 2002 | 03:13 PM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
yep...gonna need different length pushrods 'cuz roller lifters are 'taller'.
If you like the LT1 cam, why not just score one of those...should be plentiful over of CamaroZ28.com. Probably could land one for approx $30. I did, but then changed my mind and went with a LT4 HOT.
Good luck on your quest.
Old Oct 22, 2002 | 03:19 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i know that they make retro-fit roller cams
BUT
why cant you just use a regular roller cam in a non-roller block?
Old Oct 22, 2002 | 03:20 PM
DURTYBIRD's Avatar
Oops!
Old Oct 22, 2002 | 04:35 PM
Old Oct 22, 2002 | 05:29 PM
Brian'sIROC's Avatar
I don't think you can. The lifter bosses are different (shorter) which could cause a flat tappet lifter to bind. Also, the block is machined for the thrust bushing which could cause issues with a non roller cam chain.
Old Oct 22, 2002 | 06:48 PM
Hulk0202's Avatar
Yeah, I thought there would be a problem with the lifter boss. I just wasn't too sure. Thanks again.
Old Oct 22, 2002 | 07:28 PM
Bort62's Avatar
The reason you can't just Stab a roller cam in a non roller block is because of the lifters, there is nothing preventing them from spinning in the bores.
Old Oct 23, 2002 | 05:22 AM
cant i just buy the aftermarket lifters then
or will the cam still not fit?
Old Oct 23, 2002 | 05:50 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Why would the taller lifter bore cause the non roller lifter to bind? The only problem I see is it would be a giant PITA to remove the flat tappet lifters from the roller bores since the lifter would be recessed down inside it.
Old Oct 23, 2002 | 06:22 AM
ede's Avatar
ede
yes you can use a flat cam in a roller block like you've already been told. you'll need cam and lifters that match plus the correct push rods for your application and the correct non roller cam timing gear set and chain
Old Oct 23, 2002 | 07:03 AM
theres a new invention out called the magnet
j/k
Old Oct 23, 2002 | 08:03 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
After a few thousand miles, a magnet will not pull lifters out. Trust me, I have tried it many times. It will pull the lifter up off the cam a bit, but not all the way out. the problem is oil gunk builds up on the circumference of the lower portion of the lifter body which does not normally ride in the bore, and prevents it from easily pulling out. I have pulled plenty of lifters out, and all of them with very many miles do this. I always wind up having to grab the lifter with a pair of pliers to pull it out. So if this happens on a roller block with flat tappet lifters, you will not be able to pull the lifter up high enough with a magnet to get pliers on it.
Old Oct 23, 2002 | 08:25 AM
ede's Avatar
ede
i use a lifter puller to remove lifters, right tool for the job, doesn't matter if they're stuck, in the hole and inch or out of it an inch.
Old Oct 23, 2002 | 03:11 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Big screwdriver and a hammer can fix any stubborn lifter problems.
Old Oct 23, 2002 | 07:00 PM
i did a search and found an answer to my question
yes i can use the roller cam in an older block, i just need a nose snubber thing-a-ma-jiggy from www.lingenfelter.com
Old Oct 23, 2002 | 10:52 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Cam button anyone?????
Old Oct 24, 2002 | 05:22 AM
junkcltr
Aug 2, 2019 11:12 PM
MoJoe
Sep 24, 2015 09:12 PM
gixxer92
Sep 1, 2015 04:32 PM
camaro71633
Sep 1, 2015 10:24 AM
