Dampener hits the timing chain cover!
Old Oct 22, 2002 | 12:55 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I put some oil on the crank shaft to aid the install of the harmonic dampener. Now I can't tq down the nut to 70ft #'s with out it pushing the balancer back to the timing chain. Anyone else have this problem? I'm at a complete loss.
Old Oct 22, 2002 | 01:06 PM
ede's Avatar
ede
it should hit or come real damn close to the timing gear when it's seated all the way
Old Oct 22, 2002 | 01:43 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Does it just bottom out? I'm a little afraid of f***ing things up. The Lt1 gave me enough headaches w/ clearence problems.
Old Oct 22, 2002 | 09:23 PM
Vader's Avatar
FB,
Even on the LT1, the balancer hub should bottom on the crankshaft timing sprocket. If I remember correctly, there is a forward and backward to the crank sprocket as well:
Old Oct 22, 2002 | 10:58 PM
GilmourD's Avatar
What is that sticking off the front of the block above the timing chain???
Old Oct 22, 2002 | 11:08 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Its an LT1 Its a water pump drive.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
