Hardened pushrods?
Old Oct 24, 2002 | 09:49 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Hardened pushrods?
I can't find any info on wether or not I need to use hardened pushrods with the Comp 4808-8 guideplate.
Old Oct 24, 2002 | 09:51 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Re: Hardened pushrods?
I'm pretty sure you need hardened ones any time you use a guideplate, as they come in contact with it.
I need to get some, all I've found is ones for like $100 or so.
Old Oct 24, 2002 | 10:09 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Agreed. The hardened pushrods I'm using cost about $30 or so if I recall correctly. I know they didn't cost $100, I'm sure they're hardened, and they are made by Comp Cams, for use with a roller cam.
Car: 99 Formula
Axle/Gears: 342
Originally posted by ViciousZ
[B]
awesome thanks.
Old Oct 24, 2002 | 11:44 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Like mark stated you ALWAYS use hardened pushrods with guideplates or heads with guides (ie-hole where pushrod goes through is the "guide"). you can get them for like $30 out of summit (summit brand # SUM-G6400) (comps # is CCA-7812-16, this is for Hyd flat tappet also)
Old Oct 25, 2002 | 01:16 AM
evil t/a's Avatar
[B]
Yep , I am also using the comp cams pushrods for roller cams. They were 29.99 from PAW or you can get the new from GM for 9.95 each
Old Oct 25, 2002 | 02:48 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Thanks all.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
slowsi
Oct 18, 2015 08:49 PM
mfp189
Sep 27, 2015 09:25 AM
