Fram sure drain
Old Oct 24, 2002 | 11:32 PM
Hung Start67's Avatar
Fram sure drain
well changed the oil today..5w-30 amsoil and amsoil filter as well... the sure drain worked just fine but jesus dont be in a hurry..lol...went in the house changed the kids diaper downed a coke and watched some espn..lol..pretty slow drain but did a decent job...later
Old Oct 25, 2002 | 03:09 AM
ede's Avatar
ede
glad it worked for you. to me it's a joke and from watching the comerical on tv i knew i didn't need or want one. looked at one at wal mart and i figured it'd take a while for even hot thin oil to drain out.
Old Oct 25, 2002 | 08:57 AM
Vader's Avatar
67,
Yes. Thanks for the insider info. Now we have yet another reason not to use Fram filters, just in case anyone was tempted by the gadget. Personally, I knew I didn't want one when I saw the adverts since I don't have a real problem with oil mess when the filter is removed, anyway. A large drain pan works great for me.
Old Oct 25, 2002 | 10:02 PM
BOTTLEDZ28's Avatar
Transmission: A4
the sure drain is a crock of ****. it claims no more mess. Ya right. you still have to change the oil filter. I dont know about you guys but the last time i change a filter you get a little messy. its the nature of the beast. Besides I like getting oil on my skin, it absorbs in and travels through my lood stream and gives me those crazy thoughts of 8's
Old Oct 25, 2002 | 10:35 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
My hands are a mess afterwards, but oh well.
Oh, I let the engine cool a little, so as not to burn my hands, is this a major problem?
Old Oct 26, 2002 | 11:26 PM
rezinn's Avatar
I always take a nail and poke a couple holes in the bottom of the filter and let it drain before I remove it-no mess that way.
Old Oct 27, 2002 | 07:51 AM
ede's Avatar
ede
rezinn that's a good idea, but all my cars, trucks, and tractor have side mounted filters, except for my 68, so even if i drained the filter i'd still have a bit of oil. any more i wear mechanic gloves for most work and surgon gloves for a few other things. after you get use to them your hands stay a lot cleaner and it isn't hard to work in them.
Old Oct 27, 2002 | 06:54 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I never found my stock drain plug to be much of a problem. I don't ever get a drop of oil on my hands.
But even if I did, it hardly matters. It's inevitable that I'm going to get oil all over me from removing the filter.
Old Jan 29, 2004 | 09:49 AM
MHarris's Avatar
Car: '92 Firebird w/T-Tops Black w/Tan Interior
Engine: 305 TBI
Transmission: 5 Speed
Don't know if anybody is still watchin' this post but a good way to stay clean when you change your filter is to crack it loose, (just enough to turn it by hand) stick your hand inside a grocery bag and wrap it around either your hand or the filter. Remove the filter and pull off the bag. Works great for me.
Old Jan 29, 2004 | 10:23 AM
hitman's Avatar
Car: 1992 25th Ann. Z28
Engine: 5.7 TPI - Stock
Transmission: th700 r4
Vader
Just out of curiosity... why do you not like FRAM filters??
Old Jan 29, 2004 | 01:52 PM
rezinn's Avatar
Sounds like a pretty good idea MHarris.
ede, sounds like the side mounted filters are always a little messy. The point of poking the holes is just to let some oil drain out so none spills over the top when twisting it off. I guess you'd need to drain a lot more out if it was mounted on its side, though. Probably not worth the time.
hitman, we've read a lot of studies about oil filters and found fram to just be cheap construction compared to others (amsoil, ac delco, some pep boys brands), as well as having less filtering area.
Old Jan 30, 2004 | 02:18 PM
MHarris's Avatar
Engine: 305 TBI
The plastic bag method also helps a lot when its hot.
I stick my hand in to the bottom and wrap the straps around as far down as they'll go.
When the filter starts to drain there's all that bag for it to get on and not your whole arm.
Plus when your done just pull it off inside out with the filter in hand and dispose of.
Makes cleanup much easier!
Old Jan 30, 2004 | 06:34 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Hitman,
Agent Orange Frams are the WORST. Look on the net, you'll find several oil filter comparisons, where the filters were cut open and the inner construction of the filters compared. Fram makes ONE decent filter, the X2 model, the rest are JUNK. Non-X2 Frams have cardboard end caps, the least amount of filter media, poor ADBVs, and few holes in the center tube. Compare that to a Napa Gold (Wix), a Mobil1, a K&N, or an AC-Delco. Hell even a cheap WallMart Supertech is better than a Fram. The better filters have metal endcaps, much more media, and better ADBVs. The SuperTech, M1 and K&N filters are all made by Champion Labs, good stuff. Wix is good. PurOne filters are good. AC filters are good. Frams suck. Their X2 model costs more than a K&N.
Fram used to make a decent product, but after they captured the market share, they cut corners bigtime to make more money.
But hey, it's your money, your engine. do as you see fit.
Old Jan 31, 2004 | 08:04 AM
Vader's Avatar
Originally posted by Tremo
...Fram used to make a decent product, but after they captured the market share, they cut corners bigtime to make more money.
It was no better when Fram was acquired by Allied Signal. It hasn't improved at all since Allied was folded into Honeywell Consumer Division.
Ironic, isn't it? That language is very similar to the advertising that Fram used to use heavily:
"It's your engine - You can pay me now, or pay me later..."
Looks like what goes around comes around.
Here are just a couple of those comparison sites:
http://minimopar.knizefamily.net/oil...study-faq.html
http://home.earthlink.net/~memphis3/...lters/merc.htm
http://www.ntpog.org/reviews/filters/filters.shtml
Old Jan 31, 2004 | 08:57 AM
Vader's Avatar
A few more interesting pages:
http://autopedia.com/NHTSA/nhtsa.495.html#AlliedSignal
http://www.math.uwaterloo.ca/~rblander/FRAM_recall.html
Need any more reasons to risk everything on saving a buck or two? To me, nothing at Fram has apparently changed to indicate they have addresed their quality issues, so in the interest of protecting my equipment, there is no reason to use their product in lieu of something with a much better design and service record. It doesn't matter how much they advertise - or perhaps it does. It their advertising budget were rolled into the R&D and Quality departments, they might not need to advertise as much.
Old Jan 31, 2004 | 09:48 AM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I don't find it to be that messy.. I crack it open.. and spin it toll it's about tot come off.. by that point the oil is coming down the sides.. then I leave it till it stops.. wipe off the oil, and take it off.. Though I do drain the pain totally first.. if that makes any difference.
Old Jan 31, 2004 | 10:25 AM
a73camaro's Avatar
U can always pay somebody to change your oil if you're concerned about getting dirty. So when you're at the Jiffy Lube getting serviced, you'll have time to go into the bathroom and change your tampon.
Old Jan 31, 2004 | 12:04 PM
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
hahahaha!
ya thats right, and not only will u get to change your tampon, you'll get a free newspaper too!
Old Jan 31, 2004 | 12:49 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
wow... they tought of a way to make the simplest possible task imaginable more complicated and time consuming.. sign me up.. that makes about as much sense as filling ur gas tank with dixie cups..
Old Feb 3, 2004 | 03:34 PM
MHarris's Avatar
Engine: 305 TBI
And all this time I thought you *were* supposed to fill up with dixie cups!
Does that mean you don't wash your car with Windex either?
Damn that backyard mechanic for steering me wrong.
Old Feb 3, 2004 | 04:05 PM
89RsPower!'s Avatar
yeah its a common misconception, everyone knows you're suppose to use half pint milk cartons.
Old Feb 3, 2004 | 04:08 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
I always thought Fram was supposed to be a good filter. What kind of filter is everyone using out there?
Old Feb 3, 2004 | 06:55 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Pure One
Old Feb 3, 2004 | 09:36 PM
my84firebird's Avatar
Car: 1984 Pontiac Firebird
Engine: modded 5.0
Transmission: modded 700r4
Originally posted by novass
Pure One
I've always used pure one also, very good filter. AC delcos are what most guys on here use since they're the OEM filter.
Old Feb 3, 2004 | 10:18 PM
MNformula350's Avatar
i use the AC Delco ultragaurd gold filter. and Mobil 1 15w50 oil.
Old Feb 4, 2004 | 11:34 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
Wix is a good filter, K&N is a good filter (although pricey, $9), and all the ones already stated above.
Old Feb 4, 2004 | 01:03 PM
89RsPower!'s Avatar
the K&N's are really good filters but kinda pricey and most will agree they are complete they are way overkill, still around here i just put em in the fram box and pay the sale price for em.. so i dont find em that expensive...
Old Feb 4, 2004 | 02:02 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you dont want a drop of oil on your hand taking the drain plug off...
break the bolt loose with a wrench.
push IN with your hand as you unscrew it... the pressure keeps the threads "sealed" somewhat so the oil doesnt drip out...
have your pan ready under it...
pull the plug out and UP with one motion.... there you go, not a drop on your hand.
for the filter, you can use the bag method someone mentioned... put a bag on your hand inside out or put it around the filter and all teh oil is caught in the bag....
or do what i do, stick the pan under it, crack it loose spin it off, and set it down in the pan.... its not like you cant wash your hands
Old Feb 4, 2004 | 03:11 PM
MHarris's Avatar
Engine: 305 TBI
SWEET!!! Maybe now I won't spend so much time at the pump.
Does that mean I should stop waxing my car with steel wool too? I finally perfected that brushed black aluminum look though!
Old Feb 4, 2004 | 03:27 PM
hitman's Avatar
WOW
Tremo.. Vader
Thanks for the heads up and comparisons guys. I was one of the suckers who bought the "brand" name thinking it was a better product.
I just bought my wife a new car last year and had been using Fram oil filters.... NOT ANYMORE!
:nono:
Old Feb 4, 2004 | 09:20 PM
1bdbrd's Avatar
Car: 1991 Trans Am
i use k&n filters with mobile 1 10w30 oil. i like the k&n filter because of the nice little "nut" at the bottom that i can use to partially tighten and completely loosen with a 5/8 socket.
Old Feb 4, 2004 | 10:09 PM
Tremo's Avatar
Alternatives to POS Frams
There's a lot of good filters out there. As mentioned K&N are good. Ditto for Mobil 1 filters, PureOne, Wix, Napa Gold, AC Delco, Baldwin and the Fram X2. Hell, for a decent but cheap filter, you can't beat the Supertech filters sold at WalMart. The Supertechs are made by Champion Labs who also make the K&N and M1 filters, and are cheaper and *better* than the orange Frams. You needen't use those orange Frams any longer! Orange Frams are a cheezy POS.
If you are going to use a good filter, you may as well use good oil as well. I've been using M1 5W-30 for years in my IROC. It has 140k miles on it and it doesn't smoke, doesn't leak and doesn't make wierd noises. Dig, 140k and there isn't even a blue puff when I first light it off. If you're going to spend the bucks on a Synthetic, you may as well use a *real* synthetic (group IV base stocks), which is M1. Pretend synthetics like Castrol Syntec are really group III oils.
If you really want the lowdown on oil and filters, go read the forums over on the "Bob is the oil guy" website. He looks like a crusty old right-winger, but he knows his **** about lubrication.
Also, it's interesting to learn that S&B makes a better hi-flo air filter than K&N. Better filtering, better construction, and a little less pricey. I just put a new S&B on the wife's Escort.
SRKLEGIN
Oct 29, 2015 06:38 PM
raymondandretti
Sep 27, 2015 06:43 PM
ericjon262
Sep 11, 2015 06:07 PM
89 formula TPI
Sep 7, 2015 11:06 AM
