another valve spring question???
Old Oct 25, 2002 | 04:53 PM
pskel350's Avatar
i am thinking about ordering a new cam and new rockers for my engine. i am building this engine right now, i have a set of fully ported heads, 186 castings. i am going to order a lunati cam with .455 lift. i am also going to order a set of 1.6 crane full roller rockers. by my math that will come out to a lift of .485. the heads have a professional rebuild less than 500 miles ago. do u guys think that the stock springs will hold up to that lift, and if so how long??? or should i just spend the extra money now and get to springs??
Old Oct 25, 2002 | 05:21 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Spend the extra $50 and get better springs, you will be better off in the long run.
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Get the springs. people on here say get them. I didn't since my motor had 12k miles, since I would be getting new heads. But any time I revved it up near 5k , I didn't feel comfortable.
Old Oct 25, 2002 | 05:24 PM
ede's Avatar
ede
trash the springs and get a set from comp or lunati and while you're at it get rid of the factory rotators and get aftermarket retainers. might was well replace the pull out studs and save yourself some headaches down the road.
gta90
Sep 15, 2015 04:00 PM
crazynights
Aug 21, 2015 06:53 AM
redmaroz
Aug 16, 2015 11:40 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
