fuel problems
Old Oct 26, 2002 | 09:57 PM
ninjairoc's Avatar
Car: 1986 Camaro IROC-Z
fuel problems
Will an old, possibly clogged fuel filter make my car run rough? my car sat a few years before I bought it
Old Oct 26, 2002 | 10:14 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
most definitely it will. But....what makes you think its just the fuel filter?
Old Oct 27, 2002 | 07:22 AM
Vader's Avatar
Re: fuel problems
Ninja,
A little more detail might be helpful. When was the filter last changed (how many miles on the current filter)?
What is the total mileage and what other maintenance has been done recently?
Does the engine run rough all the time, only at idle, certain conditions?
Old Oct 27, 2002 | 12:12 PM
ninjairoc's Avatar
ok i'm not sure when the last filter was changed because the car sat for a few years before I bought it. all the other regular tuneup stuff I have done - plugs, wires, rotor, cap.
My car runs rough at idle while in gear, and surges while in park. My car has 89.5K miles on it. I am changing the oil again in another 500 miles.
Also I checked my computer and it through a MAF code
Old Oct 28, 2002 | 09:18 AM
Vader's Avatar
Which code? (33, 34, or 36?)
Old Oct 28, 2002 | 05:04 PM
ninjairoc's Avatar
either 33 or 34 or both I forget
Old Oct 29, 2002 | 07:18 AM
Vader's Avatar
Scan it again, because it makes a BIG difference.
Old Oct 29, 2002 | 05:49 PM
ninjairoc's Avatar
they are maf codes but what do they each mean specifically?
Old Oct 30, 2002 | 08:14 AM
Vader's Avatar
Here's hte entire list as I have it:
GM Error Codes.pdf
You might as well download it for reference.
Old Oct 30, 2002 | 12:03 PM
ninjairoc's Avatar
How do I go about fixing either of those? what would my symptoms be for signal low - flow high and signal high - flow low? I need to find out soon this thing is killin me!
Old Oct 31, 2002 | 07:46 AM
Vader's Avatar
Your "symptoms" for either a '33' or '34' would be the same, since the ECM would ignore the MAF daa and rely on backup fuel and spark tables for operation. In essence, the engine would run, but would run rich, with low power, and poor overall performance.
The easiest way to determine which code you're getting is to scan again and note the error codes.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
