Main Bearing Specs
Old Oct 30, 2002 | 10:42 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Main Bearing Specs
I thought I was going to be assembling my L98 bottom-end this evening, but now I'm concerned.
When measuring the ID on the mains with the caps installed and torqued (no bearings), I got the following readings:
Front of #1 main measured vertically= 2.6412"
Rear of #1 main measured vertically= 2.6419"
Front of #1 main measured horiz= 2.6437"
Rear of #1 main measured horiz= 2.6428"
Mains 2-4 all measurements between 2.6416" and 2.6421"
Front of #5 main measured vertically= 2.6420"
Rear of #5 main measured vertically= 2.6425"
Front of #5 main measured horiz= 2.6409"
Rear of #5 main measured horiz= 2.6408"
(horiz measurements were made abt 1/4" above and below the parting surfaces)
I can't find a spec for this specific measurement.
I've read that a little wider horizontally is normal (and desireable) to prevent the bearing ends from gouging the crank, but don't know by how much.
What really concerns me is #5 main is narrower horizontally by .0017" .. Seems like a lot.
Should I install the bearings and re-measure?
Does the #5 main bearing get thinner near the ends?
Does block require a line boring?
Old Oct 31, 2002 | 05:46 AM
ede's Avatar
ede
i've built two or three engines and have never worried about the size of the hole, except on 4 cylinder pinto engines because they have differant size bores so you need to know to buy the bearings. only thing i've ever measured is the ID with the 2 bearing shells installed, that's what really matters, and i have checked the bearing bores for alignment with a straight edge. i don't recall ever seeing a spec on the bore size so i wouldn't worry too much about it.
6speedIROC
16
Mar 15, 2023 08:33 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
customblackbird
Oct 1, 2015 04:30 PM
gta892000
Sep 16, 2015 12:37 AM
angel2794
Sep 8, 2015 06:22 PM
