Best SBC Heads?
Old Oct 31, 2002 | 12:14 PM
usa1racing's Avatar
Best SBC Heads?
What heads will offer the best performance and value? The rest of the motor will be 10.3:1 with forged pistons and 64 cc chambers, stock rods, stock crank, Super Victor intake, 750 double pumper, 500/510 cam (probably will go bigger), 1.6 roller rockers, 4 speed, etc. I'm looking for around 215 cc intake ports, 2.05/1.60 valves, and may go up on the cam to around 600 lift, but I want 64 cc chambers to keep the compression around 10.3:1 for pump gas. I'm looking at the following heads: Brodix Track 1, Dart Pro 1, Edelbrock Victor Jr., Trick Flow regular or Big Port, Pro Topline Lightning, maybe something from AFR, World Motown Race, or Jegs High Flow 220. This is primarliy a strip car, but it will see street duty, although that's not the prime intention. Any advice? Thanks.
Old Oct 31, 2002 | 12:22 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
A lot of people on this board sem to favor the Pro Action heads.
Old Oct 31, 2002 | 12:24 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
In a way yes, but they're just starting to be used. I believe there are about 2 others I know of using them.
Do a search for Pro Lightnings on here and the review board.
AFR seems to be the most popular.
But the Pro Ls flow just with or better than AFRs I believe.
Old Oct 31, 2002 | 12:29 PM
usa1racing's Avatar
How about the Dart Pro 1's? I keep hearing good things about them from people around home.
Old Oct 31, 2002 | 12:31 PM
Car: 99 Formula
Axle/Gears: 342
Yeah, those from what I hear are very good too.
still, the flow #s for the Pro Ls speak for themselves. Also only $730 shipped, not a bad deal, course if you want aluminum that will be a tad more.
there's flow #s for the Pro Ls on this board do a search for em.
oh, and Pro Ls come with 2.08/1.6 valves.
do a search on the review board, seems quite a bit of people don't like the Trick Flow heads.
Old Oct 31, 2002 | 01:23 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
Track1s on 3rd gens have clearnace problems
I had the right side hooker supercomp touch in two places (be prepared to get real friendly with a die grinder), one was the front subframe (exhaust tube for cyl 2 I think) and the slip fit pipe for cylinder number 8. The heads are slightly wider I think had reduces that space to zero.
Old Oct 31, 2002 | 02:34 PM
usa1racing's Avatar
Has anyone used the Jegs heads yet? They're fairly new, but I would suspect they are of good quality, however, they require offset rockers.
Old Oct 31, 2002 | 07:33 PM
usa1racing's Avatar
I also looked at Canfield's. They seem to offer good flow numbers. I just wish I could find someone to take these Torquer S/R's off my hands.
Old Nov 1, 2002 | 07:38 AM
Ricktpi's Avatar
I believe the Jeg's heads are made by Canfield. I just sold my S/R's to a truck guy over on the fbody.com board.
Old Nov 1, 2002 | 07:48 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I too have heard good things about them. Scoggin dickey has the dart pro 1's and iron eagle heads. You can get the pro 1's for like 400-450 bare and the iron eagles for like 250 bare. Do a little clean up on the exhaust side and put your choice of valves, springs, and retainers.
I have always been told to get the most out of a head buy them bare and put the parts in them that you need. You may have as much in the dart pro 1's as the afr's, but you will have heads that match your needs, Dart still is a very good product to quote many engine builders around here.
With the compression you are wanting you might even get away with the iron eagles, which have good flow rates. Especially if you clean up the exhaust side.
evilstuie
Jan 9, 2020 08:29 PM
CRFred
Feb 7, 2016 11:39 PM
Mickeyruder
Sep 2, 2015 02:45 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
