King Bearings
Old Oct 31, 2002 | 06:28 PM
radiateu2's Avatar
King Bearings check out the web site
Has anyone heard of king bearings are they good or bad
Old Nov 1, 2002 | 07:14 AM
ede's Avatar
ede
never heard of them, i'd not use them. what are they? engine bearings or roller bearings?
Old Nov 1, 2002 | 09:25 AM
radiateu2's Avatar
engine bearings
EDE these are engine bearings offered by powerhouse made in israel. just never heard of them myself
Old Nov 1, 2002 | 10:33 AM
Vader's Avatar
Clevite, TRW, Federal Mogul. Those are what I'd stick with instead of trying to save a few bucks in the crank area. That would probably never turn out as an economical move.
Old Nov 1, 2002 | 10:38 AM
Morley's Avatar
Re: engine bearings
Originally posted by radiateu2
made in israel.
I'd never use anything not American made in the reciprocating assembly, especially not something as super-critical as bearings.
Old Nov 1, 2002 | 12:23 PM
ede's Avatar
ede
even if you were buying the high dollar bearings it'd still be in the 100 dollar range. like was already said i'd stick with clevite, FM ,C&A
Old Nov 1, 2002 | 02:33 PM
Vader's Avatar
Originally posted by ede
...i'd stick with clevite, FM ,C&A
Man, I need to get out more often. Childs and Albert has bearings, too?
Old Nov 1, 2002 | 03:08 PM
Morley's Avatar
Heh, for about 50 years now.
Old Nov 1, 2002 | 04:25 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
If you're referring to "King Bearing"...a distributor of bearings, seals, etc...you can specify who/what/etc make of part you want with them. Good folks to deal with.
Never heard of a manufacturer called King Bearing.
Old Nov 1, 2002 | 05:05 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
There is, in fact, a manufacturer called King Bearing, it is owned by a guy named Chris King... only problem is, he manufactures high-performance bicycle bearings!
Old Nov 1, 2002 | 06:11 PM
89ProchargedROC's Avatar
There is also a company that makes bearings for small block chevies and the like....called King. usually use the King Alecular bearings.....they are expensive but i've heard are one of best. Up there with the coated Federal Mogul and the like
Old Nov 1, 2002 | 10:51 PM
laiky's Avatar
Cleavlite 77- rods and mains under 40 bucks from summit. Sometimes it doesn't pay to be different
Old Nov 1, 2002 | 11:10 PM
radiateu2's Avatar
king bearings checkout the web site
I would like to call everyones attention to www.kingbearings.com
and then tell me what you think of these bearings. Looks and sounds better than some of the bearings some of you folks have mentioned. Since I will put this 305 together with these bearings I will let everyone know how it goes. If they work well I will put them in my stroker 383 that I am assembling this winter.
6speedIROC
16
Mar 15, 2023 08:33 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
